Madis Reivik
Hot Rolled
- Jan 23, 2011
- Estonia
Hello !
Our robo has Z axis screw like on attached picture. It actually has 2 nuts bolted together, I dont know if its for improved rigidity (iB has faster rapids compared to iA)
Problem - it makes rumbling noise and lately has started nonsmooth movement on Z axis (jumps about 0.1mm, checked with dial indicator). If I let the nut move down by weight, I can feel rumbling noise when holding screw.
And, at the ends of screw it moves a bit harder. I think because the ends are not much used during normal machining and maybe they are worn out.
My question - could there be an easy "mcgyver" fix to remove 0.1mm jumping and sticking ? I know that it needs replacement but I would like to use the old one until that (avoiding Z-sensitive work).
Maybe the balls are not circulating ? I got no experience with that. On the screw I dont see much wear or "brinelling" but of course it could be there
