Rook question about setting a radius tool in a lathe
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
    May 2017
    Oregon
    34
    33
    Default Rook question about setting a radius tool in a lathe
    I am training a fng and we are currently discussing the "proper" way to set a full radius grooving tool. He is a recent grad from a decent machining tech program at a local community college. My way is to set X and comp in the value of the radius. If I am using a 1/4 diameter grooving tool (N151.2-A250-50-5P) I would bring my tool to the OD on my part X axis is X10.0 then I comp it down 0.125" for the radius. And then Z0 comped 0.125 for the radius. he is trying to say that just the touch off point of X10.0 no comp and Z0. no comp. He doesn't get that Mastercam sets the tool off of the centerpoint of the cutter and not off of the touch off point. How do I teach this young person......
    Tom.
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    Quote Originally Posted by Tom. View Post
    hy tom if i get it right, this approach means that insert coordinate system is located in the center of the insert radius
    this approach means that insert coordinate system is located at low left corner
    you are both correct, and in both ways a program can be generated
    locations described by you are marked with blue in attached image also there may be used other locations, like the ones marked with red
    it is important to associate programing toolpath with "point" position
  3. Likes Tom., lonestar1224 liked this post
    Sep 2015
    Ohio
    1,149
    702
    1141
    Either way works as long as its reflected in the program. If that's how you do it in YOUR shop, then that's how he needs to do it.
    Why is he arguing? Does the FNG want to become the effin' unemployed guy?
  5. Likes Tom. liked this post
  6. #4
    Jun 2010
    415
    121
    140
    Quote Originally Posted by deadlykitten View Post
    Quote Originally Posted by Booze Daily View Post
    Yep. All depends on how the code is generated. Yall do it your way there, so thats how the tool must be set.
  7. #5
    May 2017
    Oregon
    34
    33
    Kitten- I am programming and setting the tool off of the insert center like your pic the top center dot. Thanks y'all
  8. #6
    May 2017
    Oregon
    34
    33
    pretty much, all he thinks is that piece of paper makes him a machinist and the kid can not even define most g-code in the program. It has gotten so bad in some places with the machining tech programs that employers (such as mine) prefer to hire the 'grads' over 7 year machinists. I told him that he is going to have to prove himself at any shop he sets foot into, eh one more FNG conversion to FUG!!!
  9. #7
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    hei Tom, i guess you can see there are more ways to skin the cat
    on a lathe with a tool setter, an operator will measure the tool more likely how your friend/aprentice suggested ...
    you should predict the effects of such cases, because if insert reference system is shifted, than things happen
    i mean you may program with the reference at the middle, but if an operator measures low-left, and it crashes or something, who will you blame ?
    also you may tell him before, but an error still may appear, because the operator may be allready used doing things in a different manner ...
    the only way to have peace of mind, is to check the offset values from program or from the control interface, or ...
  10. Likes Tom., N/A liked this post
  11. #8
    Nov 2013
    Utah
    4,638
    1222
    2601
    STFU!! dead cat.
    To the point,
    Personally, I set the tools the same way your operator does. When you program with Mastercam you select which corner to use. What difference does it make to the programmer? The reason I do it that way is because it makes it easier for the operator to verify approaches when the tool gets close to the part. It also makes it easier to do the math if you need to make fine programming adjustments. And grooves need that more often than some other turning operations.
    But one of you is going to have to bend to do it the other way, you can't both have your way.
    R
  12. Likes Philabuster, Bobw liked this post
  13. #9
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    it is possible to have it both ways ... it requires an intermediate module between program and cnc interface
  14. #10
    Sep 2010
    Victoria Australia
    3,722
    1467
    STFU!! dead cat.
    To the point,
    R
    Hello Rob,
    I'm in your camp. Setting at least the X axis on the insert edge is more intuitive than setting the centre of the radius. There is no valid reason to set a Full Radius Tool differently to Turning/Boring tools.
    Regards,
    Bill
    Just adding complication for complication sake.
  15. Likes Philabuster, Bobw, Oldwrench, N/A liked this post
  16. #11
    Jul 2006
    Arizona
    4,608
    18478
    4323
    Setting to the theoretical tool tip off of X and Z is normally how it is done with a tool probe. You just simply probe X and Z and call it good.
    It appears like the OP does not have a tool probe in his lathe so he never learned how to do things the easy way.
    And no, a piece of paper does not make a machinist.
  17. Likes Bobw, Oldwrench, rustamd liked this post
  18. #12
    Nov 2013
    Utah
    4,638
    1222
    2601
    I guess the message was not clear STFU
  19. #13
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    Quote Originally Posted by angelw View Post
    is not complication / but a solution to operator error prevention
  20. Likes Tom. liked this post
  21. #14
    Sep 2010
    Victoria Australia
    3,722
    1467
    The error prevention would be for everyone to be on the one page.
    Don't hijack this Thread with as you do with most
  22. #15
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    it is possible that Tom may keep generating programs on radius center, and an operator may measure the tool at lower-left corner
    this involves corelation between 2 different cutting edge origins
    some controls have capabilites that may be used to help this corelation
  23. #16
    Aug 2002
    West Unity, Ohio
    25,403
    5665
    8081
    I stick with X at tip and Z at apex.
    Think Snow Eh!
    Ox
  24. Likes Tom., rustamd liked this post
  25. #17
    Jul 2013
    Indiana
    3,231
    4725
    1630
    Think Snow Eh!
    Ox
    Most times I do too.
    Brent
  26. Likes Tom., BALNH, rustamd liked this post
  27. #18
    May 2017
    Oregon
    34
    33
    Quote Originally Posted by Philabuster View Post
    We have probes just not on his machine. I am the programmmer and He just quit so it is a moot point. I have learned different ways from different people, but this kid (23-25) just wanted to be billy badass machinist when he proved to the company that he is belinda bitchass machinish
  28. #19
    Nov 2013
    Utah
    4,638
    1222
    2601
    That's cool Tom, it's hard most of the time working with them. But it will come up again, maybe not groovy, but something always comes up in that topic. Programmer vs. Machinist is not the first main event ever.
    R
  29. #20
    May 2017
    Oregon
    34
    33
    That's cool Tom, Programmer vs. Machinist is not the first main event ever.
    R
    I am both, 15 years killing my body and 7 years killing my mind.
