Roto Vise
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 72
Thread: Roto Vise
    Oct 2009
    Massachusetts
    116
    9
    16
    Default Roto Vise
    I'm looking for feedback from machinist who work with the following tool.
    http://www.piersonworkholding.com/4th-axis-vise.php
    I'm looking into work holding products for a twin spindle 4 axis machine. It will not have tailstock support. This seems like a good solution.
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    Quote Originally Posted by Needshave View Post
    only of you are not machining metal, or if you are not using high specs
    ... i think you could add a flange / something, so to gain tailstock suport
    maybe you can ask for a test, so to eliminate your doubts ? that thing may be a booster for specific parts
  3. Likes digger doug liked this post
    Oct 2009
    Massachusetts
    116
    9
    16
    The rotary's are set up facing the front of the machine. Not much space to add support. I'll measure it Monday. I'm also thinking of turning a solid steel "nose", mounting them to the rotary's and then milling a flat table for a kurt toolroom vise. I like the idea of 4 vises per spindle.
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    yes, i guess you can make your own bed ( nose ) for those vices
    maybe you can use a tailstock, if your parts are small, so to use smaller vices
    also, i think you may craft a solid thing, with vices included in it ... thus the vice and the nose is one
    Oct 2005
    15,678
    Why won't it have tailstock support ?
    Oct 2009
    Massachusetts
    116
    9
    16
    The rotary's are forward on the table facing the operator. I'd like to leave them like that for operator comfort while loading. They are spaced apart the same distance as the spindles so two parts are cut at the same time.
    The parts are going to be mostly 17-4.
    Jul 2012
    Washington
    2,941
    1140
    1189
    Nice looking vise model. I notice they say a tailstock is not needed. IMO it probably depends on the rotaries more than the vise. If they are solid then I don't think tailstocks would help, and I use a tailstock to hold almost everything with my 4th.
  9. #8
    Jan 2013
    Gilbert, AZ
    6,038
    7605
    7732
    How precise is the work you are doing? I am setting one up right now. The vises precision out of the box leaves a lot to be desired!
    I spent considerable time this morning dialing my rotaries platter to within .0002" Y & Z.
    Bolted the vise up. And attacked it with an indicator.
    The indicator is all over the place checking this thing out. I would not rely on this thing to hold +-.005" on anything.
    If I zero the position with the indicator zeroed on the vise bed @ 0-deg. and roll it 90-deg. the position is off .0087 one way. And, .0068 the other.
    Repeatably, and exactly.
    Maybe the finish on the sliding surface of the move jaw could be an indication?
    And the lock-tight on the POS soft as butter Set-screw that holds the move jaws was a nice touch to fuck up an allen key I have had for 20 years without fucking up until now
  10. Likes DavidScott, Cycle1000 liked this post
  11. #9
    Apr 2010
    Wisconsin
    6,106
    4195
    3758
    Dammit. Thanks, B. You just saved me some time, money, and aggravation. Criminy. Guess I'm sticking with 5thAxis for now...
  12. Likes wheelieking71 liked this post
  13. #10
    Feb 2005
    Akron, OH
    1,864
    289
    1397
    Oh man, that's disappointing. I was looking at one too. Great idea, but "we machine rotovise parts on a rotovise!" gave me pause. You'd think they would want to machine vise parts on something a LOT more rigid, like a horizontal.
  14. #11
    Jan 2013
    Gilbert, AZ
    6,038
    7605
    7732
    Here is some more juice for you guys:
    That is the fixed jaw locating slot that the .277" pin is standing in.
    And that is the fixed jaw locating boss that mates that slot that the calipers are measuring.
    Those calipers measure that pin as .2775". So there is at least .006" clearance in the location of the fixed jaw.
    Make no mistake gentlemen. This thing is a POS. High level hobby grade.
    I am going to run the dog-shit out of it on some low tolerance production work (if I can get it to make good parts).
    I will report back how well it holds up.
    I have been administering swift and repeated kicks to myself's ass all day for not jumping on the Chick that went fairly cheap on ebay several weeks back instead!
  15. Likes digger doug, cwtoyota, Cycle1000 liked this post
  16. #12
    Oct 2009
    Massachusetts
    116
    9
    16
    The decision was made to make a fixture out of solid material to save on the cost of the vise. It was made before the posts from those who purchased it. Thanks for the feedback.
  17. #13
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    ... i would build the vice in it if something happens, you can still mill out the integrated_vices and buy real ones
    also, you may consider including only the fix jaw, and buy 4 moveable jaws
    just saying
  18. #14
    Apr 2013
    New York
    851
    733
    670
    Quote Originally Posted by wheelieking71 View Post
    Holy cow - Thanks Bill! I saw on IG a while back that you had bought one of these and was really considering one myself. I'm really, really grateful to you for sharing your challenges with it.
    As an aside, this seems to match up with just about everything else I've personally seen and heard as far as the 'quality' of stuff that comes out of the popular social media/YouTube 'machine shops'
  19. Likes wheelieking71 liked this post
  20. #15
    Apr 2010
    Wisconsin
    6,106
    4195
    3758
    Quote Originally Posted by Johnny SolidWorks View Post
    Same here.
  21. Likes wheelieking71 liked this post
  22. #16
    Jan 2015
    723
    106
    369
    Well that's kinda disappointing. I saw those on their website and thought it looked interesting and worth a try on one of my other rotaries. Lot lower profile than the home brewed one I made.
  23. #17
    Jan 2015
    723
    106
    369
    If you decide to make your own - this is what I did. Maybe give ya some idears.
  24. #18
    Apr 2010
    Wisconsin
    6,106
    4195
    3758
    Quote Originally Posted by thesidetalker View Post
    Love that.
  25. Likes Cycle1000 liked this post
  26. #19
    Jan 2013
    Gilbert, AZ
    6,038
    7605
    7732
    Pic saved!
  27. #20
    Mar 2013
    Oregon
    1,870
    757
    2205
    Or the Lang Quick Point Tri Top.
    Sucks the Pierson is looking sorta junky. I thought those guys were on it.
  28. Likes rustamd, Philabuster liked this post
