dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
I googled and googled but didn't see a machine way cover specific way to fix these.
Kitamura HX400IF with reinforced rubber way covers for x
We were doing a fair bit of dry high speed machining and the air blast and washdown coolants did not do a fair enough job to keep the chips from piling up near the operator door. They piled up in the corner where the rollup waycover retracts into, and ended up wearing a 3" tall "tear" in the bottom of the way cover in the middle of its travel. The tear is up/down, perpindicular to the x axis. It can't be sewn because while I call it a tear, there's some missing material in it, about 3/8" wide gap at the bottom.
There's also wear in the rubber surface where you can see the reinforcing material/cloth/whatever you call it. about 6" long total.
The cover is in great condition otherwise and a quote from Kitamura was awfully high.
we're currently running the machine as-is and only have a bit of coolant splashing through in that area that we can deal with, but it needs to be fixed.
So is there a patch that anyone has used that has worked well? I'm thinking of thin rubber + rubber cement or some other glue/bonding agent. Thin like bike tube thickness. Will anything be reliable winding up at full rapids going through the chip wiper on the roll side? (rapids are 1900ipm)
