I understand. I don't plan on it!
As far as how your software is using the number, I don't know the first thing about CAMWorks, but if you don't even know what you're asking about, how can you expect an answer?
There are lots of folks on here who use CAMWorks and know formulas and rules of thumb for many things. That is how I expected an answer
2) Yes it does, and I explained how to find them.
I saw your post explaining how to find them and I had expanded the "Manufacturer Speeds and Feeds" section, not the "Speeds and Feeds" section. The "Plunge RPM" and "Plunge Feed" are not listed in the "Manufacturer Speeds and Feeds" section, but I've found them now. So my bad there, and thanks for pointing that feature out!
3) If you want to learn, you have to run the machine. Each machine and setup is different, and no software in the world will accurately account for all the variances.
I do want to learn and I am learning. I don't expect the software to account for everything, but I don't want to leave gaping holes for errors to happen. That is why I want to make sure the software is configured properly and why I'm asking questions about the things I don't understand to make sure they don't bite me.
4) Yes, plunge at rapid, outside the stock or in a drilled or helix bored pilot hole.
The word "plunge" is imprecise language that is causing confusion. I've only ever seen/heard people use the term "plunge" when referring to actual cutting, not simply moving the Z axis down. There is a big difference. All the software I've used (including HSMAdvisor) also uses the term "plunge" in regard to a cutting operation. I never asked about plunge, I asked about Z feedrate. "Z feedrate" is precise language since "feedrate" implies cutting. I see there are at least two folk in this thread that are using the term "plunge" generically to mean any downward Z axis movement. Armed with this knowledge I will be sure to clarify in the
If you are a novice machinist, why do you insist we're all wrong about this?
I don't think you are "wrong", I think there is some confusion on my part and the part of others regarding specifics, and as the saying goes, the devil is in the details. I do disagree with anyone that believes what I'm asking (a formula to calculate Z feedrate, Leadin feedrate, and Leadout feedrate) is not possible because there are too many variables. It is just an equation with a lot of variables, nothing more. The fact that HSMAdvisor has a "Plunge Feed" proves there is a formula for Z feedrate. I should be able to determine what that formula is by subbing in various variables. Once I figure out what it is I'll report back.
IMO, filling out defaults in your software and then blindly relying on them is a recipe for disaster. Either half your cuts will be too aggressive and break tools, or half your cuts will be too conservative and leave money on the table. Maybe some of each.
I'm definitely not "blindly relying" on software, but I do want it to get me as close to the "correct answer" as possible. This is vitally important for a green machinist like myself, because I need/want as many guardrails in place as possible as I gain experience.
If you want to be efficient you MUST recalculate parameters for every cut. If your stickout is a little longer or shorter, your depth of cut a little deeper or shallower, your setup rigidity is a little different, each case must be recalculated if you want the optimal numbers.
This is where I again say, this is an equation that CAN be solved if we have all the variables. CAMWorks can do the calculations, that is what it is good at. Assuming solid work piece rigidity, CAMWorks has variables for everything else. It knows my tool stick out, it knows my depth of cut, it knows the work material, it knows the tool material, it knows the machine parameters, etc. I'm not saying that CAMWorks IS calculating everything correctly (maybe it is, maybe it isn't), but I am saying it is possible for a robust piece of software to take ALL the variables and spit out optimal g-code nearly every time.
