Run 30 parts then stop?
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Jan 2009
    south jersey
    130
    69
    27
    Default Run 30 parts then stop?
    I have a Hardinge Talent with a Fanuc Oi-TB control. On the setting page their is a parts count , and a parts required page. But it only counts the part if their is an M30. When I'm doing bar work with a M99 it does not register the part. Their is no auto restart switch , so this is how I get it to run a bar (M99). How can I run a specified amount then quit?
    Thanks in advance.
    Nov 2013
    Minnesota
    471
    168
    312
    Try M54 just before the M99.
    Nov 2001
    WAPELLO, IA USA
    6,407
    29
    1840
    either that or a macro counter of your own.
    Jan 2009
    south jersey
    130
    69
    27
    Quote Originally Posted by bukwerm View Post
    Just sat there at M54
    and didn't do anything.
    Jan 2009
    south jersey
    130
    69
    27
    Quote Originally Posted by WILLEO6709 View Post
    I guess once I learn to write a macro, their will be no stopping me.
    Feb 2012
    1,391
    887
    1496
    Parts counting is different from control to control. I just use macros.
    #500 = #500 + 1
    IF[#500 GE 30] GOTO100
    M99
    N100 M30
  7. Likes mhajicek, TeachMePlease, JMC liked this post
    Jul 2012
    North Carolina
    292
    275
    114
    Loop it 30 times?
  9. Likes Greg White, DavidScott liked this post
  10. #8
    Jan 2006
    New York
    1,611
    697
    788
    O1000
    M98 P301111 (P1111 is your prog with the M99 in it. The 30 after the P is the number of loops)
    M30
    or another way
    O1000
    M98 P1111L30 (1111 is your prog with the M99 in it L30 is loop 30 times )
    M30
    If 1 format doesn't work, the other generally will.
  11. Likes ranchak liked this post
  12. #9
    Nov 2013
    Minnesota
    471
    168
    312
    Either a macro or subprogram loop will do the trick. The advantage to those methods is that they can be applied to other problems as well.
    If you want to just use an M code try checking parameter #6710. On the 0i-tc that's were the part count M code is specified.
  13. Likes bartthefarmer liked this post
  14. #10
    Nov 2013
    Minnesota
    471
    168
    312
    Here's what I mean.
  15. #11
    Mar 2007
    warren, mi
    1,186
    126
    306
    my hardinge cobra has a parameter that you can set for auto repeat with a barfeeder. you still end the program with M30 and then the parts counter works. look for the auto repeat.
  16. #12
    Jan 2009
    south jersey
    130
    69
    27
    Quote Originally Posted by chip_maker View Post
    O1000
    M30
    Took yesterday off and went fishing
    This is what I went with this morning and works great. Thanks
    Thanks for all the replys ,I will play around with these when a get some more time.
    This place is the best when you are a one man band and need a little help.
  17. Likes chip_maker liked this post
  18. #13
    Sep 2013
    Ohio
    346
    196
    176
    You can also do redundant tooling with auto tool change macro. PM me and I will send you an example.
  19. #14
    Jun 2012
    Michigan
    4,809
    4414
    2911
    Here's what I mean.
    This counter only counts the M30.
    Our machine uses M12 for the counter... Hyundai-Kia... it has an external counter on the front of the control and every time it sees an M12, it adds +1.
  20. #15
    Nov 2013
    Minnesota
    471
    168
    312
    Quote Originally Posted by Mtndew View Post
    Not sure I'm understanding you... My machine most definitely adds to the parts counter every time M54 is read. If I wanted to use M12 as my count code I'd replace the 54 in my pic with 12. M12 might be specified as some other function in my control though, hence someone else's comment about specific part count code varying.
    With no idea of the op's experience I suppose I really should have said to use caution when trying the M54. No idea what his machine builders have specified for that code.
    Once the parts count equals the parts required then the machine alarms out and stops. The nice thing about using the macro and/or subcall methods with counting is they don't throw an alarm. (unless programmed to) A program can be written so the machine stops at a set number of parts and then continue on when cycle start is hit. No worries that way about an operator having to reset or change anything in order to keep running.
  21. #16
    Dec 2002
    Granville,NY,USA
    3,934
    333
    428
    Quote Originally Posted by Orange Vise View Post
    #500 = #500 + 1
    M99
    N100 M30
    This is how I do it. Except I assign another variable to be my part qty like #501. Then on my variable page set 501 to what ever I want for a count
    If you are going to run the program over and over make sure you put a #500=0 before your M30 so that it is reset for next time.
  22. #17
    Jan 2009
    south jersey
    130
    69
    27
    Just had a few minutes to check this out. M97 is what is specified there.
    Sub program loop is working great but nice to know other options, if I have to interrupt the loop this might be a better way to go.. No operators to worry about, except me.
  23. #18
    Aug 2002
    West Unity, Ohio
    25,540
    5781
    8164
    The loop counter on the sub call is a slight help, but once you stop it in the middle of the bar - You are SOL.
    I think that you can add other M calls to the counter library.
    I don't know the param number off the top of my head.
    Glance through the params and you may find it.
    Think Snow Eh!
    Ox
  24. #19
    Nov 2013
    Minnesota
    471
    168
    312
    Quote Originally Posted by FOXFIRE View Post
    In my case that's the operator that usually gives me the most problems.
  25. Likes Mtndew, toolsteel, swatkins, aj liked this post
  26. #20
    May 2008
    SOUTH AFRICA
    1,627
    1191
    667
    M12 must be a Kia thing. Mine, SKT21, uses M12 as the counter and no other M code even M30.
