Paul from Doosan helped me out..............quite simple......................Put the large tool in the middle pocket and zero both pockets on either side of the tool. Call the large tool with a tool change..............T28 M06. Then when I need the next tool, don't stage it. Run
only an M06 and it puts the large tool right back into the same pocket it came out of and
then call the next tool...........T2 M06.............
T28 M06;
M06;
T2 M06;
Thinking out loud just to confirm I'm right
...............But I was looking at the tool sizes.........Doosan says max tool Ø is 80mm(3.150")..............I will be running a 4"Ø slitting saw. It would still easily fit in any pocket as long as non of the other tools exceeded roughly 2.3" or so..............right? All of the other tools I have in the carousel are under 2" Ø. Max tool Ø would be two 3.150"Ø tools side by side(center to center distance of the tool pockets). So I should be able to run this 4" saw next anything that is smaller than 2.3"Ø
......No need to designate it as large just as long as I don't run anything else large(bigger than 2.3")? Right?!?!???..................
