Hey guys,
I am selling one of my machines (Fadal VMC15) and have had a few questions regarding power. The plate on this machine says full load amps is 40A (at 220V). Is anyone running one of these on an undersized breaker? I know people do this all the time with HAAS mills, and I'm pretty sure I've heard of people doing it without issue for Fadals but I wanted to check.
Anyone running a VMC15 or similar with a 30A breaker (on 220/208V)?
Thanks!
-Aaron
The VMC 15 claims a 7.5 HP spindle motor ≈ 5.6 KW.
208 V equates to
29.91 Amps (single phase) with a power factor of 0.9 for "Syncronous(sp) motors" .
220 V equates to
28.21 Amps (single phase) with a power factor of 0.9 for "Syncronous(sp) motors" .
Three phase you get very little current draw.
for example
220 V (line to line
three phase) [power factor 0.9] ---> (
16 Amps).
220 V ( line to
neutral three phase) [powerfactor 0.9] ---> (
9 Amps).
Kilowatts to amps (A) conversion calculator
double check with on line embedded app. ^^^
Fadal VMC 15 CNC Milling Machine Model# 914-15 Serial# 012000020244 -- Claims
Volts 230/440 3 Phase 40/20 Amps Travel X 20" x Y 16" x Z 20" Table Size 29.5" x 16" Spindle RPM 7,500 Spindle Motor 7.5 HP Cat 40 tapered spindle 21 tool Automatic Tool Changer Coolant
dum de dum de dum. [Probably unlikely all servos will be energized all at the same time at maximum draw.].
For your future buyer or client can you wire it into a 30Amp single phase breaker (at the box) to see if to goes OK ? (before hand, 208V versus 220 is only slight difference of about a single Amp at single phase.).
^^^ This seems to fit what folks have said so far in this thread also.
The "Power factor" is a bit of a fudge / fiddle factor on other motors at maximum draw with zero resistance theoretically the spike could be as high as 70 Amps (on a power factor of 0.35 ).
The "spike " maximum draw may be so quick / short that it doesn't have enough time to really trip a breaker (maybe) other wise it's probably running / coasting along much like what
triumph406 has indicated.
_______________________________________________________________________________________________
Just some extra butt covering / won't catch fire etc.
