joeymorgans
- Nov 20, 2021
Hi everyone,
I've been looking at filling my machine with a LANG or 5th axis 'zero point' system. No more setting datums, standardised set ups and fast set-up changes!
That's all great for jobs that are held in a vice or on a dedicated fixture. But what about all the one-off, large plate work? I don't see how these systems accommodate for that?
The best option I can see at the moment is to make my own sacrificial plate that fills the machine table (maybe out of 3x separate pieces for ease of loading), and mount studs to the bottom of it so it can be mounted on top of the zero point system. I think that would work well.
So then I started looking at sacrificial plates, but there isn't really much info out there! I want something that does the following:
-Has threaded clamping holes.
-With precision c'bores for locating.
-Has plugs over the holes to block swarf building up.
-Can be drilled into and tapped into (but not milled into - I will stay off 0.05mm)
-And if possible, be able to minimum clean up the top surface whenever it gets knackered.
So my question is, what do you guys use as a large sacrificial plate? Any pictures would be very helpful!
Joe
Joe
