SAE Porting in Inconel
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Nov 2015
    Colorado
    553
    113
    327
    Default SAE Porting in Inconel
    Good day,
    Has anyone here got experience with O-ring boss porting using Inconel 718? Job coming up is going to require a bunch of SAE ports in this lovely material and was wondering what your thoughts are. My only experience using form ports is exactly zero. I assume a carbide tipped SAE form will cut the inco just fine but at an extremely slow speed. Use like a reamer, predrill, circle mill, port, thread mill. Job done. Except I assume tool wear will be a factor here. The holes themselves are pretty small, 7/16-20 SAE, 1/2-20 SAE, 5/16-24SAE.
    How critical is the thread gaging for an SAE port? Are go/no-go gages the way to go here?
    These are near-net complex forms that I would really like to not screw off on because they are expensive and have long lead times.
    Jun 2011
    New Jersey
    1,726
    936
    756
    Definitely use go/go gauges.
    Watch the speeds, tools can get cooked easily.
    The tool maker will tell you what to run at - stat at the low end and work up.
    A rigid setup is a must.
  3. Likes metalmadness liked this post
    Feb 2014
    FL
    4,596
    13961
    5618
    Quote Originally Posted by DouglasJRizzo View Post
    Hmmm.... If I used go/go gages, I'd never have scrap!
  5. Likes pr0xify, metalmadness, Bobw, Mtndew, barbter and 1 others liked this post
  6. #4
    Jan 2014
    Temecula, Ca
    3,453
    1428
    4476
    Quote Originally Posted by TeachMePlease View Post
    but aren't go-go threads expected to strip?
  7. #5
    Jan 2014
    Temecula, Ca
    3,453
    1428
    4476
    I would prefer to turn a port in inconel rather than use a porting tool. What does the part look like?
  8. Likes BSCustoms liked this post
  9. #6
    Nov 2015
    Colorado
    553
    113
    327
    Quote Originally Posted by Larry Dickman View Post
    These are 3D printed rocket engine parts so....yea not really fit for turning as the ports are located not along center. There may be some that could be turned but I am not sure about that quite yet.
  10. #7
    Oct 2005
    22,565
    "Larry Rimshot Dickman".....
  11. Likes barbter, Cole2534 liked this post
  12. #8
    Jun 2012
    Michigan
    6,167
    5771
    3939
    My experience with the porting tools is somewhat limited, but I'm pretty sure they thrive on a very stable setup, otherwise they tend to chatter.
    Others may have had better luck with them but I don't like them. If it's a mill job, I'd look at profiling them if the form tool doesn't work like it should.
  13. #9
    Feb 2005
    9,812
    16829
    12021
    Port tools suck..
    The price of port tools sucks.
    The geometry of port tools sucks.
    Just thinking out loud.. I wonder if you would be money and time
    ahead to have a carbide tool made that had the correct form, but
    smaller, and with better geometry than a barn door.. And then
    interpolate the form. kind of like threadmilling instead of tapping.
    The threaded portion at the bottom can be brought to size with a drill,
    and if you need the counter bore/flat at the top, you can do that with
    an endmill.
  14. Likes MCritchley, Jashley73, barbter liked this post
  15. #10
    Feb 2014
    FL
    4,596
    13961
    5618
    Only if they drop out of college.
  16. Likes Bobw, atex57, doug925, Winterfalke liked this post
  17. #11
    Nov 2005
    1,593
    19
    198
    I think fluting would be a challenge for an all in one. But if you were to drill the pilot hole and only have to do the chamfers I think you'd be fine.
    IMHO, drill the hole, stay a chamfer distance short of the bottom, rough mill the counterbore with a small stock allowance, then use the port tool to finish it. The material at the bottom of the hole will provide stability for the tool using the drill point.
  18. Likes Micmac1 liked this post
  19. #12
    Jan 2014
    Temecula, Ca
    3,453
    1428
    4476
    Quote Originally Posted by Bobw View Post
    Actually, I have a customer who does this on hard shit, like D-2
    They say it works great, plus you can do different size ports with the same tool
  20. Likes Bobw liked this post
  21. #13
    Aug 2015
    Utah
    10
    28
    I see a lot of guys here talking down on port tools. I've used them in Inconel with good results. When running a port tool, good runout, a rigid setup, and even stock removal are the keys to success. Follow the manufacturers recommendation for the speeds and feeds, and you should end up with a consistent, quality port every time.
  22. #14
    Nov 2015
    Colorado
    553
    113
    327
    Port tools suck..
    an endmill.
    Sadly I have neither the time nor money to get a custom form tool ground. Though that would be ideal!
  23. #15
    Nov 2015
    Colorado
    553
    113
    327
    Quote Originally Posted by Zeuserdoo View Post
    I like to hear it. Have you any suggestions for setting up a recipe for success outside of speeds and feeds from the mfg? Like how much stock to leave for the porting operation?
  24. #16
    Nov 2015
    Colorado
    553
    113
    327
    Quote Originally Posted by huskermcdoogle View Post
    This sounds like a good idea
  25. #17
    Feb 2005
    9,812
    16829
    12021
    Quote Originally Posted by metalmadness View Post
    Sadly, looking at the prices of HSS port tools now on McMaster Carr. You might be money
    ahead having a handful of customs made, and even paying for an expedite fee.
    I swear they used to be like $50 for HSS and maybe $120 for the brazed carbide ones.
    I think the most I paid was $450, but it was some odd ball F'd up port spec that only one
    company had in stock, and it was brazed carbide, which I didn't need, since it was
    30 holes in aluminum.
  26. #18
    Aug 2015
    Utah
    10
    28
    Here you go. Inconel 625 AS4375-06 port.
    Stock for finishing: Floors .004, Walls .007 (per side,) Thru bore drilled .006 under size.
    Solid Carbide Port Tool AlTiN coated: SFM 112, feed 1.85 IPM
  27. Likes barbter liked this post
  28. #19
    Oct 2007
    SPAIN
    5,364
    1193
    659
    Port tools suck..
    an endmill.
    Winner Winner KFC for dinner!
    :belch:
  29. #20
    Sep 2017
    Wisconsin
    1,479
    392
    947
    I have found the Scientific Cutting Tools brazed carbide units to be pretty economical, but there are inserted options out there as well that I've used. Only ever in aluminum or normal steels, though.
