christie628
- Nov 12, 2018
Just recently purchased a used 2010 Samsung SL25 lathe that had been sitting for a few months. Put it under power and backup batteries for axis were low, Replaced them only to find MDI touch panel was not working. All control buttons would work but non of the mdi so i couldn't home the machine . Jump two days later while searching wiring for loose connections i found a blown 5a fuse in the control panel. I replaced the fuse and powered the controller back on to black screen , It wont boot at all. Tried cycling power to the machine / went back through fuses and all were good including the one i had replaced.
In the machine cabinet the controller driver shows a alarm :
Alarm:
A data transfer alarm for the
nonvolatile memory has been
issued.
Countermeasure:
Turn the power off then back on.
If this alarm recurs. replace the
servo amplifier module.
Tried several reboots to no avail .
Is there a controller issue or is the servo amplifier really bad ? All the servo amp have the double horizontal hash with no faults.
Alarm:
issued.
Countermeasure:
