Sandvik (Tamrock) water temperature
Results 1 to 10 of 10
    Aug 2019
    CANADA
    Ontario
    Default Sandvik (Tamrock) water temperature
    My Sandvik scout 700 Rock Drill's water temperature goes up and it beeps after about an hour of work and I have to turn it off.
    What are the possible sources of this issue?
    Is there any operator manual or troubleshooting for Sandvik rock drill?
    Jan 2014
    Washington
    5,279
    953
    2915
    This has to set a record for the most OT thread ever posted here!
    Feb 2008
    MI, USA
    895
    69
    363
    Maybe it has a 0i control on it???
    Feb 2014
    FL
    3,680
    12202
    4321
    Quote Originally Posted by dandrummerman21 View Post
    It IS made by Sandvik...
  5. Likes Mtndew liked this post
    Oct 2005
    18,891
    Must have a FANÜC control on it....
    Feb 2008
    MI, USA
    895
    69
    363
    I think we can work through this, although this isn't the normal kind of drilling most of us do.
    Without knowing ANYTHING about what you're working with:
    Does it have a cooler/radiator? Is it pumping water through? Is it cooling (if there is an active cooling compressor on it)? Does it have enough water in it?
    Seems it has a temperature gage. Does it appear to be as warm as it thinks it is? Is the sensor or gage faulty?
    Beyond that, perhaps bearings are bad and need replacing. Or you're working it too hard.
    FYI this is a forum about machining, and you have posted in a CNC machining board, which is for precision machining (think making parts out of steel or aluminum). You've got the wrong forum for this. But keep in mind the questions I wrote above. Maybe you can find the answer if you check those things.
    Oct 2005
    18,891
    Or......they can just go ask over at www.heavyequipmentforums.com...and get a proper answer,
    one from some that's been there, and doing that.....
  9. #8
    Feb 2008
    MI, USA
    895
    69
    363
    Nooooo, I'm emotionally invested in figuring it out!
    Do you think they just googled "Sandvik drill forum" and clicked the first result to get here?
    Edit: Just checked, 2nd result.
  10. Likes TeachMePlease liked this post
  11. #9
    Feb 2012
    1,450
    910
    1620
    Need more information.
    What color is the drill?
  12. #10
    Jan 2019
    Arizona
    1,082
    100
    419
    Quote Originally Posted by Orange Vise View Post
    before or after it gets hot?
