Hi all,
Først of all, thanks for the help indtil now with all this probing stuff. I get more help here than with the Company that sold the machine to the Company I work for... When I call the tech department, the first thing they say is, are you the guy up north doing all that stuff with the machine? Answer is yes, an mostly with a Q they need a couple of days to figure out, if they answer at all...
There are thin fine TS27R mounted in the machine, but it has never been used with the macros from Renishaw. So my Qs right now is about the calibrating program for the stylus, and first of all the settings Macro O9750.
The O9750
#101 first probe touch feed rate. What do you guys use?
#113, #114, and #117 initial approach, secondary approach and overtrawel.
The calibrating part.
The tool used, what do you use? I would like to use something neat and precise, but what du you use?
I'll start with this, more will be asked along the way:-)
Cheers,
Daniel
The O9750
Cheers,
Daniel
