Hello all,
I'm looking for any creative ideas or paths for the following problem on a Mori Seiki CNC lathe (NLX 2000).
We are using a certain insert (GRIP 6030Y) which has a tool life of ~30 minutes for our application thus this insert is frequently changed. We've noticed that every time this insert is changed we scrap a part or few trying to get the part back in size and this scrap is really adding up.
We are concerned with three features; the ID size (X offset), Race location (Z offset), and Radius of the ID (R comp). All three of these characteristics are defined by this one tool. We try not change the R comp. unless necessary as the machine has a happy place for it given that our tolerance for the radius is +/- .001." Also, the tolerance for the ID and race location are +/- .00025" and +/- .001," respectively. Additionally, the parts are copper plated adding a whole other dimension of variation due to changing copper thickness from part to part. Although, for this problem lets assume the variation is negligible as we working with our vendor to solve this.
At the moment, we are working to develop a procedure to back off the X and Z offsets every time the insert is changed and then slowly come in. This will certainly help but one scrap part is certainly guaranteed as re-machining the ID several times seems to throw the radius out of tolerance.
Surely that one scrap could be better than our current situation but are there any other possible solutions to this problem or improvements for our procedure? FYI I'm somewhat new to the CNC world so anything help!
Thanks!!
Thanks!!
