Searching New VMC
Results 1 to 7 of 7
    Jan 2018
    MEXICO
    49
    7
    8
    Default Searching New VMC
    Hello!!
    I'm in charge of innovations and new projects in the company I work.
    We make progressive dies and we are looking to buy a medium-large new VMC.
    We might have budget to buy a ≈ 80" x 40" size machine.
    I already quoted two machines, HAAS VF-7 and Pinnacle LV 209. Does anyone has references about Pinnacle machines? In Mexico they are not well known but they say that are far superior from Haas and I've seen the way they are build and the Pinnacle LV 209 seems be a good machine. That might be true, I believe that buying a VF-7 is not the best option because is the same structure as a VF-4 but larger.
    Can someone tell me other medium-large machines that I can quote, I've seen a OKK VM76R but is not that big and I believe is expensive, the VM76R is around 60" x 30", but it seems to be very rigid machine.
    I would really appreciate if someone can give me some advise of which machine could be a good option.
    Thank you!
    Jan 2014
    Washington
    5,882
    1017
    3312
    Place I retired from had an Okuma V852 and it was a superb machine. Not quite to the 80x40 envelope though but Okuma has a model V1052 that is. I suspect it would be an excellent machine just like the smaller V852. Not likely that your budget will make it to Okuma quality if you are looking at Haas or the no name Pinnacle.
  3. Likes ArturoMeltri liked this post
    Jan 2018
    MEXICO
    49
    7
    8
    I'm not looking at them, those are the only ones I've already quoted. I'm looking for other options because I don't really know other options. I'm going to look at that Okuma you are talking about!
    The reality is that Pinnacle is as you sayd, no name. No one knows that brand but I've seen the construction and it seems really intersting.
    Thank you!
    Jan 2014
    Washington
    5,882
    1017
    3312
    Quote Originally Posted by ArturoMeltri View Post
    ....The reality is that Pinnacle is as you sayd, no name. No one knows that brand but I've seen the construction and it seems really intersting.
    If you do not have really good abilities to repair and troubleshoot CNCs you might be in trouble with a brand like this despite looking well made.
    Jan 2007
    New Jersey
    1,346
    750
    800
    You might want to look at a Doosam Mynx 9500/50. I work for Doosan and know that Doosan is heavily supported in Mexico. The 9500 is a very rigid, box way machine with a travel of 98" X 37" X 33".
    SPECIFICATIONS:
    CAPACITY:
    X axis travel 2,500 mm (98.425")
    Y axis travel 950 mm (37.4")
    Z axis travel 850 mm (33.46")
    Table loading area 2,500 mm x 950 mm
    (98.425" x 37.4")
    Allowable table load 3,500 kg (7,716 lbs)
    Table T - slot spacing x width (5) - 160 mm x 22H8 (5) - 6.3" x .866
    SPINDLE:
    Spindle nose to table top 200 mm to 1,050 mm (7.874" to 41.338")
    Big plus Spindle system CAT 50 Big Plus
    Spindle speed 6,000 rpm
    AC Spindle Motor (30 min. rating) 18.5 / 22 kW (25 / 30 hp)
    Spindle Torque (30 min. rating) 452.5 nm (334 ft-lbs)
    Spindle Acceleration \ Deceleration time 0 - 6k (3.6 sec) \ 6k - 0 (2.6 sec)
    Feb 2006
    Republic of Texas
    3,013
    I have a re-badged Kao Ming V1500 60 X 30 X 30 box way 6000rpm 32 tools That I have been pretty happy with. This is largest C frame machine they make. They have double column machines that are larger. Double-Column Machining Center | Taiwan | KAO MING Machinery Mexico rep: Bienvenidos a Alttek - Alta Tecnologia en CNC
    Jan 2018
    MEXICO
    49
    7
    8
    Quote Originally Posted by LockNut View Post
    SPECIFICATIONS:
    CAPACITY:
    (98.425" x 37.4")
    SPINDLE:
    Thank you, I will talk with my local seller about that machine.
    I only knew the DNM Series and they seem to be great machines!
