How do you chose which tool holder to get? If you can get a ER50 with a hole for say a 3mm or 1/8in tool, how is that different to an ER8 collet holding the same 3mm or 1/8in tool?
Also, how do you know that cramming the largest tool for a given collet WAS a bad idea? Say you take an ER20 collet and then cram the largest 13mm tool in there. They designed the system in a way that it should all work right? I mean if it fits, it should work? No?
