chevydyl
- Nov 23, 2014
- Sterling, Ak
hey fellas, so as the title says, myself in the garage upgraded from a M50 to the much faster M64B-M. bout a year ago i had trouble with the 50 so i bought an M65, DOA. luckily though the 50 regained its heartbeat. so i swapped the 65 for a 64, also bought the base i/o board, dx-451. i tried to install it but found it to be more than i wanted to do, the plc is not compatible. so back to the 50, until about 3wks ago. it just died, i took it apart did some soldering and tossed it into the oven bam, back online for about 20 mins. rinse repeat about 15 more times until it finally just wouldnt boot. so..... m64 back in the cab, i knew what that meant, hand entering the ladder 2000 something steps yuck. i put the 50s all1 and parameters in. it boots, it moves, but huh.... its a M64B-D.rill control, no work offsets, No Spec it says when trying to set g54. 17kb of memory, so, many hours on the phone with Mitsubishi, then emailing. the 50s all1 options wouldnt not unlock on the 64. so mitsubishi, went above and beyond and sent me an All1 that was from a like machine with a 64. Boom we are now a 64M-B, machining center control! and....48 work offset expansion, high accuracy control mode, screen graphics, remote program input, computer link b, base 32k of memory, my 50 had 128k but i cant complain, my tool and spindle routines are on the control, and with computer link b running at 38400 baud, its a rocket ship now, 4 times faster than the 50, plus computer link b has a 32kb input buffer, not no 5 blocks lol. the machine is everything i wanted it to be now. i think i spent $400 on the control and the base i/o, next stop full 4th! would also like to replace the crt and keyboard.
i do have a question though, i need parameters for the high accuracy control mode, setting in the book range from 0-999999, anyone out there can share these settings with me?
