Parkerbender
Stainless
- Dec 19, 2009
- Kansas City Mo, USA
Okay, I decided to move this to the forums, as to quit filling up Bloke's (roooster on here, bloke at the 'zone) PM-box (sorry!) and also so someone can be helped, if they have the same problem. Additionally, I know this is on the 'zone too, http://www.(site which will remain nameless).com/forums/hurco/120674-motion_control_problem_servo_amp.html#post885809 there are lots of people who don't cross over, and it's seeming that I need all the help I can get...
Okay, I have a problem where when I put power to the servo drives, my x-axis takes off about an inch and a half, then faults out the drive. The encoder reads correctly when I turn the ballscrew by hand, and it is wired normally.
Here are the clues:
If you switch the A+ to B+, B+ to A+, A- to B-, and B- to A- on the encoder, the x axis runs correctly, but in reverse. (when you hit the + jog it goes in the - direction)
When the encoder is correctly wired, and the three plugs are in the original Max400 servo drive, the table jumps to the right (negative in cartesian coordinates) for an inch or two, then faults the 'X-axis Servo Amp' when the start button is pressed upon startup to power the drives
When the encoder is correctly wired, and the three plugs are in the Y-axis Max400 servo drive, the table jumps to the left (positive in cartesian coordinates) for an inch or two, then faults the 'X-axis Servo Amp' when the start button is pressed upon startup to power the drives
When the encoder is wired up with A and B swapped, so you can give power to the drives without faulting out, the Y and Z axis both work correctly.
Given these symptoms, what might a person think that it can be?
Here are the clues:
