Generic Default
- Jan 23, 2016
- Wilmington / Long Beach
It seems like on most newer (not ancient) cnc machines, there are no weight counterbalances for vertical axes and the servos for these axes just use a constant torque output to keep the ballscrews from back-driving, which would crash the spindle or turret into the table or mechanical stop. The servos have brakes on them to hold stuff in place when machines are off or E stops are active.
I'm curious about how much energy is used since the brakes are apparently solenoid driven and must be energized in order for axes to move. Does anybody know the wattage these servos use when the brakes are not engaged? And how much power does it take for the Z servo to hold up a typical VMC headstock?
