Servo II Software
Results 1 to 13 of 13
    Feb 2007
    Missouri
    11
    Default Servo II Software
    I've got a Servo 5000 CNC bed mill that is currently running the DOS version control. Wondering if anyone has the Windows version on their Servo mill. Getting tired of paying the "sneaker net" floppy disk shuffle between a real computer and the mill. I've considered trying to force DOS to recognize USB or Ethernet. I've also considered trying to make the mill run under a Windows XP DOS shell. I know, I know - this is not recommended because of the non-real time capability of Windows, but it might be interesting to try.
    Would like to hear from any other Servo owners to see how you are dealing with floppy-only file transfers or if you are using the Windows version of the control software.
    Aug 2006
    Illinois
    14
    Hey Dan,
    We have the same mill.
    I didn't know they even had a windows version, never needed it.
    We have used Zip drives to do backups and large file transfers.
    Could you possibly do a serial connection PC to PC?
    As far as the USB, I think you could maybe do a windows 98 sp2 boot
    If you can find the drivers, does your servo PC have USB?
    Good luck!
    Jeff
    Feb 2007
    Missouri
    11
    Hi Jeff,
    Thanks for the reply. Servo did offer a Windows version of the control, but I've never talked to anyone who uses it. I have thought about doing a serial link to my main PC. Might not be a bad way to go if all else fails. The motherboard in my mill's control does have a USB header that should allow me to connect a cable to two USB jacks. I'm pretty sure DOS won't know what to do with the USB ports without a special driver which is probably available. Need to do a little more research on this.
    How did you connect up your Zip drive to your control?
    Dan
    Aug 2006
    Illinois
    14
    I just used a parallel port model.
    You might be able to find some on ebay.
    I have the 100MB model and I think they made a 250MB version too.
    Feb 2007
    Missouri
    11
    Thanks for the info Jeff.
    I'm still interested in hearing from and other Servo mill owners on the forum. Anyone running Windows on their machine?
    Jan 2003
    Tel Aviv, Israel
    538
    73
    98
    During years I installed here over 100 SERVOII systems, some 50 of them still in use. Although many times being forced by customers (because of the difficulty finding DOS running PCs) to upgrade (?) to XP version, I was quite reluctant to do that. Too many conditions, and supplier not being able to give guarantee that the
    software will run on locally supplied computer, even if exactly fulfilled the specifications.
    The USB problem was solved by running win98, capable to deal with it. The SERVO software was executed in DOS shell.
    SERVOII is great system, and I am quite frequently asked to supply additional systems.
  7. Likes slemachining, BDGiven liked this post
    Feb 2007
    Missouri
    11
    Probe,
    So you were able to get the Servo II software to run under a DOS shell with Win 98?
  9. #8
    Jan 2003
    Tel Aviv, Israel
    538
    73
    98
    Quote Originally Posted by MotoDan View Post
    Probe,
    Yes, I was.
    Important is to go to shell, and not execute in window.
    Communication parameters to be set in Control Panels.
  10. #9
    Sep 2016
    Florida
    7
    do you use a dongle if so where can i get one ?
  11. #10
    Sep 2016
    Florida
    7
    hello i have servo systems II on my acer ultima 3axis machine. came with the quick n easy software but no dongle! or controller....
    i have my buddy building me a dos machine so i can load the sofware on put it this way its a pain in the ASS!
    i went another way i bought 32 bit windows xp I might buy the xp software but its 1990.00 dollars yup its $$$
    my question is this is there any way i can transfer nc code to the machine useing my lap top with mastercam x4
    any help would be great this is my first cnc im only 28 just dont know anybody to ask! lil desperate!
  12. Likes brian068 liked this post
  13. #11
    Sep 2014
    Florida
    Did you ever figure this out? I bought a mill with the servo II also
  14. #12
    Oct 2013
    New Jersey
    1,054
    883
    We have a Servo 5000 that was upgraded to the Windows computer in 2010 by the previous owner who then couldn't get it to run at all. We bought it in 2017 knowing that the CNC might be dead. When we plugged all the cables back in after the move it ran perfectly! 100 hours on the machine, a 12" 4th axis with a 10" six jaw chuck that had never been connected to the machine and 23 Nikken Tool Holders, 7 with Jacobs super chucks, for $6000.
    We like the Windows computer simply because we run CamBam along side of it which lets us program parts in the office and edit them right on the machine. For $150 CamBam does a really good job for us.
    The Windows version uses an RTU program from a 3rd party to get real time operation. The worse part about the whole thing is the tool length compensation. After a tool change the Z doesn't show where the end of the tool is, it shows where the reference plane is! I complained to ServoSource about it because it makes the tool length compensation virtually worthless.
  15. #13
    Apr 2015
    Tennessee
    138
    96
    20
    anyone have one for sale I'm looking we have have one at work and I'm fixing it now. But think this would be a sweet machine for my home shop.
