Setting Offsets (G54) in ShopTurn with 810D
mattdlr
Jul 18, 2018
Leicestershire, UK
Edit: I meant to write "Siemens 810D Control" in title. Doesn't look like it's possible to edit titles.
Hi All
New to post here but been here for a while.
For a while now I've been trying to workout if there is a GCode line I can use to set the work offset with ShopTurn on a Siemens 810D control (the machine is a Hardinge).
I've googled it and read some manuals but could never get it to work. I want to just add a line at the top of the program to set the G54 for each program.
For example I'd like to set the Z G54 work offset to 100mm.
In normal gcode that would be something like "G10 L2 P1 G90 Z100.0" I can't get this to work with this control though. Does any one have experience with ShopTurn/Siemens controls?
I'm sure it must be something simple.
Thanks in advance
you can do a
trans z100
its part of the frames concept of seimens. trans by itself will cancel the frame completely. so if you had x or y transformations it cancels them to
Thanks for the responses. TRANS puts an offset into the program only which will probably work. I was hoping to be able to set my work offset (G54) from the program and it stay set even after the program ends.
SIM, G58 doesn't do anything, is G58 the work offset that you use or do you use G58 as a means to set a work offset? Either way my machine errored out when I tried "G58 X0 Z100."
Off topic but do either of you use a network/computer attached to your Siemens 810D (I've never managed to get it to work)?
try this
$P_UIFR[1]=CTRANS(Z,11.500) ; G54
$P_UIFR[2]=CTRANS(Z,43.710) ; G55
$P_UIFR[3]=CTRANS(Z,22.222) ; G56
$P_UIFR[4]=CTRANS(Z,22.222) ; G57
I use G10 to load the Fanuc's like that, but I never knew the Siemens way.
I may implement that as well.
Thanks!
Think Snow Eh!
Ox
Thanks!
Think Snow Eh!
Ox
OX have you ever tried to use G54P1, G54P2, G54P3 on your 810 control?
I'm trying to decide the best way to set up a pallet and repeat a part 20 times. I don't want to use all my G511,512,513....because they are already set for other jobs.
Other option I haven't played with yet is to try and create a looping program with maybe an R value that adds to the G54 x and y off set. Haven't quite got my head around it just yet.
