srp61
- Sep 19, 2009
- Dunedin, New Zealand
So our Cincinatti FTV840 with itnc530 control appears not to have had any of the settings set for Cycle 32(which is the high speed machining mode)
I suspect Cincinatti never set it up as highspeed roughing(and finishing) wasn't all that popular 15 years ago.
anyway the machine can be painfully slow to rough parts as its basically working in a tightly controlled feed-forward mode, you could call it high accuracy mode.
Id like to try setting up the HSC modes for finishing and roughing and I've got a pretty good idea how to tune the filters and jerk parameters using the built in oscilloscope however what I cant seem to figure out is how the machine knows what parameters to use when cycle 32 is set to 0 or 1(finishing/roughing), from what i can see in the manuals I can set certain values in manual or automatic operation, but nothing related to cycle 32.
I'm kind of thinking that there needs to be some plc logic to switch to a subset of parameters for the different modes but I again can't find any reference to cycle 32 setting any markers for the plc to read to do this.
This is a long shot but if anyone out there is familiar with setting up Heidenhain controls and could help out that would be awesome
Regards
Andrew
Regards
Andrew
