sidetrack50
- Jul 1, 2014
- Indiana
Hello everyone,
I finally got my 3 phase up and running with power to my Fadal. I need some advice on a few things. It's been a long time since I ran a Fadal (30 yrs) and even then I only ran and programmed it, never set one up or maintenance.
1. Need to hook up the coolant pump (has 3 plugs)
2. Need to remove the 3/4" shafts holding up the counter weight (shafts are bent from the weight)
3. Need to remove the blocking under the spindle so I guess I need to jog the Z-axis up a little (will machine move positions when I turn on the power?
4. I've seen a lot of manuals online but not sure what the best ones to purchase, need one for maintenance and programming.
5. I found two 1" drain plugs in a small bag, for oil?
6. There was a air hose apparatus inside the machine not sure what it is.
Any help is appreciated, Mel
