I am trying to use a Multi Directional Turning tool to do some profiling on aluminum (specifically an ISCAR TGDR -4 type). To achieve the profile I am using the round nose insert, radius is 0.079. It squeals like Ned Beatty in 'Deliverance', especially when feeding in X, cutting on the right hand side of the radius. Less so on the left hand side (which generally means the tool is feeding out in X). It happens even in light depth of cut passes. I have explored a range of speeds and feeds without any real difference, though I am running very slowly for carbide in aluminum. The usual 'decrease speed increase feed' does not seem to work here - though I haven't pushed anything to the breaking point yet .
These tool holders have a very narrow section, like a cut off blade. Is this the nature of the beast? Would using a more square, small corner radius insert make a big difference? That wouldn't help on my finish pass anyway, because the profile cannot be achieved with that insert. In the MDT videos from Iscar, Seco, and others they show going after steel much more aggressively than I am attacking this aluminum. Wonder what I am doing wrong? Is running at low SFM making the problem worse?
