jeffeosso
Hot Rolled
- Jan 23, 2004
- Porter, Tx
Howdy,
I am in the process of fitting my manual BP J into cnc... and wanted to hear from others that have gone this route, or have refitted a nc/cnc machine to pc control.
In my case, I am taking a fairly accurate manual, that I had fitted a turret powerfeed to, replacing that powerfeed and couple with a much more accurate one, utilizing the acme screws, on the first attempt, and using the knee for Z.
Why knee? I have a right angle head and wish to be able to use it, and I am willing to "suffer" with slower feedrates
I bought John's 600oz servos and geckos, and will be doing a 2:1 on x/y and a 3:1 on Z, along with gas strut(s) on the knee to help lift it.
My goal it to have a machine that can make parts that basically can be held in one's hands... monoblocks, sights, "go kart" frame pieces, at this time, the biggest piece i can see machining, and that will be in fortal aluminum, is a bellhousing for a bmw v12 to a caddy northstar motor.
I'll be "tucking" the Y and Z motors, hopefully one a "one piece" frame across the front. Sure it'll be a couple pieces, but it will probably be .75 fortal, and then welded (tig) into one piece at the end of the day.
I am planning on the MINIMUM modifications to the BP as possible, as I know that I may refit with ballscrews at another date.
i'll keep you posted
jeffe
jeffe
