Sharing a Macro Conditional Branching Math Experience...
Results 1 to 13 of 13
    Aug 2013
    Chicago, IL
    1,058
    758
    415
    Default Sharing a Macro Conditional Branching Math Experience...
    Hi Everyone! I recently ran into something that I thought I would share at the outside chance that someone who reads this might retain it and help them should they run into the same issue:
    I was setting up a new process where I had to mill a slot .675" deep. It was polar interpolation on a lathe, something I had very little experience with, so I knew I was going to have to experiment with various cutting parameters including DOC. I wrote a subroutine for the individual mill path in X and "C" (Y) and instead of editing a bunch of individual Z depths every time I wanted to alter the DOC I wrote a macro that would increase the depth of cut by some amount that could readily be altered and keep calling up that sub routine until we were at full depth. From there it would jump to the finish pass (I left .002" on the walls for finishing.)
    To make sure the roughing passes ended up at .675" I made sure the DOC I plugged in was an even multiple of .675". For instance, if I put in .100" for DOC I would either end up a .600", leaving .075" on the floor for finishing (too much for me), or at .700", blasting .025" past the nominal depth. I could have made a safer macro but that is not the point of this post. The program looked something like this:
    #501=0(ZEROING THE COUNTER);
    #502=XXX(DEPTH OF CUT);
    N100;
    #501=[#501-#502];
    Z[#501];
    M98P200;
    IF[#501GT-.675]GOTO100;
    FINISH PASS;
    M30;
    N200;
    ROUGH PASS;
    M99;
    So if we put .025 in for "XXX" it will step its way down 27 even passes to .675" then do the finish pass, and it did that just fine. But then I changed the DOC to .03375 (for 20 even passes) it went one roughing pass too far! I double checked the math, ran another part, saw (and took a picture of) the POS screen that displayed the Z position as precisely "-.675", which should have prevented the program from "GOTO100" and instead should have just gone to the finish pass.
    I do not know EXACTLY what happened but I assume there is a binary rounding thing going on that rounded the .03375" down to .0337" so after 20 passes it would have been at Z-.674" and thusly qualify for another roughing pass, .0337" deeper. at about Z-.707". (I am sure the POS screen said "-.675" and not "-.674"....I took a picture!)
    The part stick out was just enough that the extra pass didn't hit the collet but nevertheless I thought I would share the experience in case anyone else is left wondering "what went wrong" if it ever happens to them...
    OH YEAH, in the meantime I just changed the condition to "IF[#501GT.670]GOTO100" I know that's super lazy but I just had to get the job done and knew any extra material left on the floors from a rounding error would be no more than .001/.002" so I was fine with that.
    Jan 2014
    Washington
    5,277
    952
    2914
    I think had you used GE rather than GT it would have worked as you intended.
  3. Likes 3t3d liked this post
    Sep 2010
    Victoria Australia
    3,918
    1591
    Quote Originally Posted by Nerdlinger View Post
    N100;
    #501=[#501-#502];
    Z[#501];
    M98P200;
    FINISH PASS;
    M30;
    N200;
    ROUGH PASS;
    M99;
    Hello Nerdlinger,
    Calculations are carried out in binary and may result in unexpected results when comparing the values of two variables. Accordingly, subtract one variable from the other and compare the Absolute value with a tolerance value is the "work around". If the result is Greater or Smaller (depending on the logic you want to use) than the tolerance, then the Macro Statement will Test True. A logical tolerance to use when testing the two variables to be equal, would be the Least Programable Increment of the machine, as this will have insignificant, or no influence on the actual coordinate.
    Therefore, your following Block
    could be replaced with
    IF [ABS[ABS[-0.675] - ABS[#501]] GT 0.0001] GOTO100
    Using Common, Nonvolatile variables (#500 Series) is poor practice when Local Scope variable would suffice. Also, a better way of writing your above program is as follows. This method doesn't require the Full Depth to be exactly divisible by the DOC.
    (DECLARE VARIABLES HERE)
    #1 = 0.0 (Z Start Point)
    #2 = -0.03 (DOC INCLUDING DIRECTION)
    #3 = -0.675 (FULL DEPTH)
    WHILE [#1 GT #3] DO1
    #1 = #1 + #2
    IF[#1 LT #3] TH #1 = #3 (STOP OVER CUT IN Z)
    G01 Z#1 F_ _
    M98 P200
    END1
    Quote Originally Posted by Vancbiker
    Hello Kevin,
    Using GE would actually force an extra DOC. The OP's Macro Statement with GT will Test True and return to N100 if Full Depth has not been reached. If #501 were to be Equal to -0.675 the program should not return to N100, but continue with the remainder of the program.
    Regards,
    Bill
  5. Likes Nerdlinger, 3t3d liked this post
  6. #4
    Sep 2010
    india
    1,294
    73
    233
    As explained by Bill, it was caused by floating point error in calculations, not because of rounding to 0.0337
    If the DOC is added 20 times, it may not be exactly 0.675
    Even if it is 0.67495, the position display would be the rounded 0.6750
    For confirmation, check the value stored in #501 in the end.
  7. Likes Nerdlinger liked this post
  8. #5
    Sep 2010
    india
    1,294
    73
    233
    Default Rounding/Truncation in axis addresses
    Another thing to mention is, rounding/truncation is automatically done by the control if there are more number of decimal digits than the least-input-increment decimal digits (3 in metric and 4 in imperial, in increment system B) in an axis address. Rounding is done if the value is specified through a variable, and truncation is done if the value is directly specified as a constant. For example, in mm mode,
    #1 = 100.2345
    G00 X#1
    would place the tool at X = 100.235
    I refer to this as "implicit" rounding which is equivalent to
    G00 X[ROUND[#1]] (In axis addresses, ROUNDing is done up to 3 decimal digits in mm mode)
    But,
    G00 X100.2345 would place the tool at X = 100.234
  9. Likes Nerdlinger liked this post
  10. #6
    Aug 2013
    Chicago, IL
    1,058
    758
    415
    Quote Originally Posted by angelw View Post
    Hello Nerdlinger,
    #1 = #1 + #2
    G01 Z#1 F_ _
    M98 P200
    END1
    Regards,
    Bill
    Thank you Bill! I knew I could have written a safer code but not as clean as the one you proposed. I should really get more comfy with the other functions, conditions, etc. available....there is more to life than just IF[...]GOTOn . Thanks, again!
  11. #7
    Aug 2013
    Chicago, IL
    1,058
    758
    415
    Quote Originally Posted by sinha View Post
    Thank you, Sinha! I remember checking both the POS screen AND the MACRO screen and seeing "-.675" for the Z position and value for #501, so the error must have been retained somewhere behind the scenes. Interesting info regarding the differing aspects of rounding/truncation! Thank you, again!
  12. #8
    Jan 2014
    Washington
    5,277
    952
    2914
    ......Hello Kevin,
    Regards,
    Bill
    Oh duh. Yes. I didn't thoroughly read the code.
  13. #9
    Sep 2010
    india
    1,294
    73
    233
    Typically, an error of 10 to-the-power -10 gets introduced in each arithmetic calculation. Therefore, #501 is definitely not equal to -0.675 after 20 additions. However, it would not show up on the macro variable screen which can show only 8 digits, in the rounded form. Therefore, even though the display is -0.675, the value stored is slightly different.
    Likewise, there are errors in all macro-function evaluations. For example,
    the exact value of SQRT[2] is 1.414213562373095...
    But the display would be 1.4142135624 while the value stored would be different from this, though not equal to the exact value.
    For the same reasons, the condition [SIN[0] EQ 0] would be always FALSE unless parameter 6004#1 is set to 1 (which normalizes the result to 0 whenever the calculated value of SIN/COS/TAN is less than 10 to-the-power -8)
  14. #10
    Dec 2007
    Southeastern US
    6,384
    845
    2808
    For these reasons, I will often use the number of passes as the branching factor, not an actual measurement resultant from a complex calculation. While the possibility exists that it could still screw up 1.00000000000 + 1.00000000000, the likelihood of it doing so is greatly diminished.
  15. #11
    Sep 2010
    Victoria Australia
    3,918
    1591
    Quote Originally Posted by Tonytn36 View Post
    Hello Tony,
    Error in Binary Calculations occur because of the fixed number of binary digits to represent a decimal number. Accordingly, some decimal numbers can’t be represented exactly in binary, resulting in small roundoff errors. The representation of Integers doesn't have this issue and therefore, 1.00000000000 + 1.00000000000 will equal 2.00000000000 and so on with further additions of Integers.
    Regards,
    Bill
  16. Likes yardbird liked this post
  17. #12
    Jul 2013
    Indiana
    3,313
    4873
    1690
    Hello Tony,
    Regards,
    Bill
    Hello Bill,
    I for one didn't understand why or how any calculation errors occurred or could even happen until now. That's crystal clear and makes perfect sense.
    Brent
  18. #13
    Sep 2010
    india
    1,294
    73
    233
    What I still do not know is why, even today,
    1. Memory is an issue with CNC ?
    2. The in-built calculator of an ordinary computer is more accurate than CNC ?
