dalt.deuel
- Apr 19, 2018
I am having trouble getting sharp corners when I am programming angles. The larger the angle the bigger the chamfer on the corner.
I've also hand written program with G-Code as well as used Opticam and got the same result.
Below is a picture of what is happening and also the program that I ran to get the result.
P.S. if I take G41 out of the program i get a sharp angle.
Picture should be rotated 90 Degrees clockwise. I want the angle to be sharp and I do not know what is causing it to have a notch in it.
G20 g80 g49 g40 g90;
t7 m06;
g00 g54 g49 z0. M05;
s1030 m03;
g00 g90 x-0.38 y0.38;
g43 z0.17 h07 m08;
g01 z-0.1 f18.;
g01 g41 x0. Y0. D07;
y1.;
y-1. X1.5;
y-1.;
x0.5;
y0. X0.;
g40 x-0.5 y0.5;
m30;
t7 m06;
s1030 m03;
g43 z0.17 h07 m08;
g01 z-0.1 f18.;
y1.;
y-1. X1.5;
y-1.;
x0.5;
y0. X0.;
g40 x-0.5 y0.5;
m30;
