Hi, I went to look at a Shiz ST-N today that was pulled off the line a few weeks ago, so not under power. It was used in a ligher production shop and i get the idea it was occasional use -for at least the last 20 yrs.
There were two key issues that were said to be wrong with it.
A)Maybe encoder error? Occasionally the X or Y axis would jump forward and break a tool - sounded like it was a controller issue.
B)Plastic Gear? They said it made a thump/knock sound as it started up that was related to "a plastic gear" in it? And seemed to think it diminished at higher rpm (they weren't really positive on this!) but was the most prevalent at low rpm during rpm ramp. I believe they were told it was a plastic gear by their machine mechanic.
Can anyone shed light on what this may be wrt plastic gear?
is it common issue?
parts available?
does it show up on the AN-S?
any insight would be helpful.
Does it look like these are steppers or servos - they didn't know?
I would be purchasing this with likley the idea of Gecko / mach 3 conversion. Probably abort the Bandit even if is currently works.
Thx for you thoughts on it - trying to make a decision tomorrow - go or no go.
Paul G
is it common issue?
parts available?
Paul G
