Hello, I am in a current debate within my shop and am looking for outside input on this scenario. The machine is a twin turret lathe, the upper turret has an X and Y axis and the lower turret only has an X axis. The current set-up is using a live tool holder with an endmill on the upper turret with the tools axis line colinear with the sub spindle. The question that is up for to debate is how to adjust this tool when it is doing some complex rotary milling using the X, Y, and C axis'. One side of the argument states that you need to dial the X and Y axis of the tool center to the C axis then adjust X to compensate the tool. The other side states that you need to dial the X and Y axis of the tool center to the C axis then use the radial compensation to adjust the tool. Any input would be greatly appreciated.
