Shrink fit broken tool removal? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Jul 2006
    Hillsboro, New Hampshire
    8,219
    1939
    5797
    OR an adapter for the end of a .45 into the back of the Holder. Literally just use the bullet, and shoot it out. Quit messing around with black powder. Easy fix.
    R
    That only works for holders half inch and above...
  2. #22
    Jun 2012
    Michigan
    10,418
    3549
    3715
    I think it will be tough to remove because the holder need be made hot very quickly so thwe tool does not also expand.
  3. #23
    Jul 2006
    8,219
    1939
    5797
    Quote Originally Posted by michiganbuck View Post
    Shouldn't be that hard, the steel used has about twice the CTE as carbide. As others have mentioned, there's a chance that burring of the holder caused by tool breakage is complicating matters.
  4. #24
    Nov 2013
    Utah
    4,707
    1248
    2632
    Because half inch and above would be safe!!! Hahaha splitting hairs, if the net result is the same.....
    R
  5. #25
    Jul 2006
    8,219
    1939
    5797
    R
    I guess I should have smilied my other reply...
  6. #26
    Sep 2018
    Michigan
    43
    10
    17
    Quote Originally Posted by mmurray70 View Post
    Pull the stud out, push a rod through the backside, keep light pressure on rod and heat the holder with propane torch until it pops out.
    I wouldn't recommend this, you will ruin the holder. I destroyed one of mine just by cycling it twice in the induction heater to get a broken endmill out.
  7. #27
    Oct 2019
    Florida
    32
    5
    Alright ill share my solution, I've been out of machining for a while but started helping a guy a few weeks ago. We ran into this issue so while the vf3 was doing its thing I hopped on the manual lathe and whipped this up from scrap. It is spring loaded and screws into the PS hole. Worked well except the braze rod I used bends when hot(got the two broke endmills pushed out though.) I’m thinking about making a small run and using hardened h13 for the push rod and hot bluing them; any interest?
  8. Likes mmurray70, PegroProX440 liked this post
  9. #28
    Jan 2003
    373
    61
    102
    Quote Originally Posted by TheBigLebowski View Post
    Not much to loose, the holder isnt any good with a broken tool in it.
    Lots of cheap ass people using propane torches with heat shrink tools everyday. It should be fine, probably wont even need to get all the way to normal expanded temperature as this includes some clearance for tolerances. In this case as soon as theres any clearance at all tool pops out. Keep the heat even and it will be fine.
  10. #29
    Nov 2018
    ALAND ISLANDS
    64
    57
    35
    I think i seen Peter Stanton heat one up with a torch once not sure, but if thats the case he must be a cheap a** like me ive never had a problem doing it but then i don’t concentrate the heat in one place
  11. #30
    Dec 2003
    poulsbo, wa, usa
    902
    67
    388
    I have also been a cheap A** for the last 5 years ,,, I think I have used two $6 bottles of map gas and have changed out a couple hundred tools ,,, one of my 3/8" holders Techniks holders has been changed out well over a 100 times and it still has a runout of like .0002 on the tool shank ,,,
    I don`t see a point in spending 10K when a $30 torch from home bump gets the job done ...
  12. Likes mmurray70 liked this post
  13. #31
    Nov 2013
    Utah
    4,707
    1248
    2632
    I see smiley faces in every post, whether they are there or not. I assume everyone is as sarcastic and hilarious as I am.
    R
  14. Likes Triaged liked this post
