Shrink fit tools without a shrink fit machine.
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Jul 2018
    112
    22
    20
    Default Shrink fit tools without a shrink fit machine.
    I've been trying to move to shrink fit for some time now, but unfortunately I keep spending money on Lang stuff, which is making it tough for me convince the owner to buy a shrink fit setup.
    Anyway I've got a job coming up with a lot of tight clearance issues and long reach nonsense. I'm hoping to get a few shrink fit holders and shrink what I need for this job. It's aluminum, so the tools will last the job.
    So does anyone know any legitimate ways, albeit slow or cumbersome, to shrink tools into holders without the machine.
    Apr 2015
    AUSTRALIA
    571
    33
    134
    Most likely the best bet to avoid damaging anything would be to send tooling out to a shop with the correct gear get them to mount it and pay a fee for doing it.
    see the tooling provider they may do it as well, just send your cutters to them.
  3. Likes BRIAN.T liked this post
    Mar 2013
    Oregon
    1,725
    708
    1985
    Quote Originally Posted by BRIAN.T View Post
    Getting tools into a shrink fit holder is easy enough with a MAP gas torch. Just keep the heat even around the tip with full 360 coverage...
    Getting tools OUT of a shrink fit holder with a torch, is an entirely different matter and a total nightmare, even when the tool isn't broken. Getting broken tools out is often almost totally unsuccessful without a major set of headaches.
  5. Likes barbter, BRIAN.T liked this post
  6. #4
    Oct 2007
    SPAIN
    3,184
    1694
    1116
    +1 with a gas torch.
    You have to heat "hard and fast" with your hand spinning round the holder to keep the colour uniform.
    Don't let the colours creep to the pull stud end...
  7. #5
    Nov 2014
    Florida
    3,430
    1480
    1621
    If you need long reach narrow nose, try these, no shrink required, but limited to 1/4" and under.
    Slim-Fit CAT40 and CAT50 Advanced Collet Chuck Tool Holders for CNC Machines
    They come in cat40/50, Hsk, and BT styles.
  8. Likes Red James, Ox, empwoer liked this post
  9. #6
    Feb 2007
    Aberdeen, UK
    3,502
    1217
    1308
    Sounds like your usage requirements are similar to mine when I go for shrink fit.
    If you're not concerned about getting the tools out again, then mapp gas torch is quick, easy and painless.
    It takes two people really, one to rotate the holder while heating it, one to hold the torch and insert the tool. I place the holder in a large bearing so it spins easy while heating.
    Same as you, mine have all been for aluminium, so I haven't had to try to remove any of them yet.
    They don't usually require very much heat to expand them enough to get the tool in. I have a couple that are not even discoloured.
  10. #7
    Jan 2009
    Ohio
    830
    190
    362
    I've read in other threads that if using map gas, easiest way to complete task it to put holder in manual lathe and low RPM to assist in getting the best/even heat distribution given the method.
  11. #8
    Feb 2007
    Aberdeen, UK
    3,502
    1217
    1308
    Quote Originally Posted by countryboy1966 View Post
    I've always been afraid of getting it stuck before it is fully in (as has happened to me several times in the past shrinking sleeves on things etc.), so doing it vertically so the tool drops in cleanly has always seems more appealing to me.
  12. Likes ManicMetalBasher liked this post
  13. #9
    Feb 2018
    Washington
    41
    62
    25
    I have been using Mini-Ductor with great success. Rolled custom coil for the tools so it slips over the nose of the tool and just heat it up. I have removed end-mills with it without any problems. I keep my tool holder in Lyndex Tool Jaw. I've been wanting to make some custom setup to hold Mini-Ductor but never got to it.
  14. #10
    Oct 2007
    SPAIN
    3,184
    1694
    1116
    Quote Originally Posted by coffeetek View Post
    DINGDINGDING THAT's a winner right there!
  15. #11
    Mar 2012
    North Carolina
    362
    1055
    143
    I used a torch for a year before I got a machine.... slow but works fine.
  16. Likes mhajicek liked this post
  17. #12
    Feb 2007
    Aberdeen, UK
    3,502
    1217
    1308
    I've pondered over those things before.
    On ebay I can buy a power unit and a holder that takes preformed coils for about £600. I was always worried that they wouldn't have enough power (A typical shrinker is about 4-5KW as best as I can tell), and would just be a waste of money.
    If they work ok it would be relatively inexpensive to build a platform for it and even water cool the coil if necessary.
    The entire reason I have refused to buy a shrinker machine up til now is that they are horrendously overpriced for what's in them.
  18. Likes empwoer liked this post
  19. #13
    Jul 2018
    112
    22
    20
    I have considered these for other tools, however most of my long reach work is fine with Er16, this job I'll need at least 1/2 shank or bigger.
  20. #14
    Jul 2018
    112
    22
    20
    Now this is an interesting idea, I can get behind $400. How often do you find yourself switching tools with this thing? Aside from it being slower and slightly more difficult to use then a machine (I assume, but also don't care) do you ever have any issues with it? I'm almost certainly sold. I really appreciate the suggestion!
  21. #15
    Jul 2018
    112
    22
    20
    Quote Originally Posted by PegroProX440 View Post
    Any issues changing tools? Like some other users suggested?
  22. #16
    Feb 2018
    Washington
    41
    62
    25
    I don't switch tools often, they last forever in aluminum, but I did switch few times and it worked without any issues. If you work fast you can heat holder up to remove the tool and slip new one in without heating holder again. Wear heat resistant gloves though!
  23. #17
    Sep 2018
    264
    312
    110
    the only issues i've had using a torch with heat shrink is on a small (1/8") endmill. it broke and the shank was inside the bore. ended up destroying the holder. 1/4" and up tools i've had no issues with using a torch.
  24. #18
    Nov 2011
    CANADA
    573
    40
    175
    I use a propane torch for 8mm and smaller. Anything larger I would use the machine.
    Good quality shrink tooling like slimline has had no negative effects using a torch. I have 18 yr old shrink tooling that's still perfect.
  25. #19
    Mar 2013
    Oregon
    1,725
    708
    1985
    Mini-Ductor?
  26. Likes wheelieking71, BRIAN.T liked this post
  27. #20
    Apr 2016
    Florida
    366
    291
    116
    As far as getting stubborn tools out...could you make an air fitting with a pull stud thread, and just apply some air pressure while heating the holder? Pointy end away from face, of course.
  28. Likes rokbottom liked this post
