sneebot
Stainless
- May 14, 2001
- Massachusetts
I have a new (used) machine coming with a Fanuc 0iMD control and a side mounted 20 position tool changer. I have some questions about the tool changer/ control combination.
-Initially loading tools into the machine sounds like you would do a tool call (T7M6 for example) and then manually load the T7 tool in the spindle do another tool call and repeat.
-This brings up: are tools higher than T20 allowed in the tool changer? If so how does one know what (out of the 100s of tools) the control current thinks are in the tool changer? If not why have so many offsets?
-I'm confused as to how the Fanuc control tracks where tools are in the tool changer, from what I've read there is no pot or position number in the tool offsets table. If you want to remove (for example) T5 and replace it with T55 how do you tell the control you are performing this operation?
Any illumination on the logic of this system would be helpful.
