Rube-the-newb
- Jul 8, 2012
- Dallas/Ft Worth
Hello all,
I'm using my nephew Ruben's account, cause last night I tried to create on and couldn't - that's when he told me he had used my shop e-mail to create an account a while ago on this forum and over on ***zone...
Anyway, a couple of months ago I bought an older Emco-Maier Emcoturn 465 lathe with a Siemens 840C control. All was well, came in on the truck fine, installed Ok and powered up fine. Got it running a job pretty straight off using the on-control programming functions while I was trying to figure out the comm's. Ruben's been running it after classes with that.
Well, just got PCIN loaded and got it wired for comm's... I think. Problem is that I was just getting ready to try it out yesterday to backup the files and such (if it worked) and started the machine up to find out the battery died over the weekend. The Lithium 9V battery was supposed to generate an alarm and give you some warning - so much for that.
Now it tells me the NCK & PLC need to be reloaded... Here's the clencher - the diskette that supposedly had the backup on it won't read at all on my PC's (I'm thinking it may be formatted to the FAT or FAT32 file structure might be why). I may be able to get that figured out, I'm going to scare up an older PC with the older architecture in place and try the diskette.
SO, my question is where do I start. I don't really know what the NCK or PLC reload process is. I've given the Emco Maier office a call and they started a service ticket, but no help yet this morning. Anyway if you know where I should start or what manual contains the destructions on how to reload the NCK and PLC parameters I could really use your help.
Regards,
Jimmy Garza
Regards,
Jimmy Garza
