Simple Slot Survey - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #41
    Aug 2013
    Chicago, IL
    1,319
    977
    526
    Thanks for all the continued input on this seemingly-straight-forward feature! We've been using a trochoidal path but I was redesigning/rebuilding the fixture so I wanted to use it as an opportunity to review how to do it to make sure it is "up-to-date." I will continue to use the trochoidal path for a while to establish a baseline tool cost/life vs cycle time and go from there. Here is a video of the "unpolished" tool path (lots of air cutting, etc.) It's like S6500F185. I think the step over might be 7%. It's a four-flute 3/8" SGS. I wonder if the machine would be able to keep up with the resulting feed rate from more flutes Thank you, again!
    Trochoidal Milling - YouTube
  2. Likes BROTHERFRANK liked this post
  3. #42
    Sep 2017
    Wisconsin
    1,568
    420
    1004
    That's cooking. I use the 5-Flute V-Carbs from SGS and love them. I've got some with hundreds of hours in the cut that won't die. I keep grabbing them back out of the "to be resharpened" bin and using them for roughing, then putting them back LOL.
    With a 3/8" you should have plenty of clearance for adding another flute and still having great chip evacuation.
  4. Likes Nerdlinger liked this post
