Hi sigurdACVW:
I'm with plastikdreams when he recommends the biggest cutter you can stuff down the hole and still interpolate.
You could get a 6 mm 4 flute in there, or if you want a bigger interpolation circle and more room for the chips use a 5 mm.
I'm also with Nagol when he recommends not helixing it down the hole, but rather dropping right down to depth and circle interpolating out.
Set up a rougher and a separate finisher.
Rough to within 0.001" on the desired diameter, comping out as needed with each hole until a 0.249 gauge pin will just go in.
Switch to your finishing cutter, reset the comp a tenth at a time and kiss them all until your desired dowel will slide in.
Write your code so you can run each hole individually, and you can cut, measure, reset comp, cut again, measure again etc etc on one hole at a time.
You don't want to cycle through all the holes then reset the comp and cycle through them all again or you'll end up with loose holes and tight holes
If you rough them all first, and then finish them all with a new cutter you can get them each to a nice sliding fit if you're patient and don't mind playing with the comp as the finishing cutter begins to wear.
You can even run three cutters in succession if you're super anal and want it the very best it can be.
Cheers
Marcus
