Heya all! I have a project I am working on with the Fadal 4020. Shortening and cutting lightening slots in these 1045 steel gear blanks.
2019-11-20_06-32-34 by Jackson Edwards
The problem I am having is short tool life on the end mill I am cutting these slots with. I am getting roughly 60 parts per tool (600 slots) after swapping feeds, speeds, ramp angles and even a few different kinds of tools,
The best combination I have found is:
.3125 Maritool variable 4fl TiAlN for tool steel w .02 radius
Running Mobil soluble oil 100 at a fairly high concentration.
340sfm 4200rpm 7IPM .0004ipt (seems light, but breaks if I lower spindle speed, and breaks if I increase feed rate)
4° profile ramp, this does roughly five zigzags to the bottom. Slot is .340" deep, about 1.2xD
6ipm 14 thou radial finish pass, as the ramping cut leaves a bit to be desired.
Things I have tried:
A straight plunge to 100% depth and slot works some of the time, but depending on coolant stream angle, it will chip load and fail randomly.
Plunge to 1/2 depth and slot works ok, but The tip .150 wears and fails faster than the ramping pass does.
I pulled an end mill after ~50 parts and you can see the degradation on the cutting edges on the bottom edges, as well as the sides about ~.130" up the flute.
2019-11-20_06-55-36 by Jackson Edwards
2019-11-20_06-55-48 by Jackson Edwards
Thanks!
Thanks!
