Small taps in aluminum?
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Feb 2004
    Napa, CA
    2,632
    45
    698
    Default Small taps in aluminum?
    I need to tap a bunch of blind holes in 6061, 2 mm x 0.4 x about 10 deep. I've not done small stuff like this before. Should I use a floating holder or rigid tap? What speed would be a conservative starting point? Hoping not to break too many of these dinky taps. I usually tap very slowly (usually in SS), but there are about 800 holes to do here.
    Jun 2006
    Melbourne Australia
    544
    143
    30
    I'd be inclined to form the threads on a machine with rigid tapping.
    I've had success forming M4 x 0.7 20mm deep in 304 stainless with these:
    https://www.walter-tools.com/SiteCol...ng-2009-en.pdf
    Good luck.
    Apr 2005
    Beaverdam, Virginia
    8,341
    975
    4090
    Whatever you do a good quality aluminum will save a lot of nightmares, say no to Chinese crap.
  4. Likes Larry Dickman, Bobw, swarf_rat, DanASM liked this post
    Jul 2006
    Wisconsin
    1,420
    269
    1010
    Done alot of M2x.4mm in 6061 Kaiser select precision rod. Form tap, held rigid in collet chuck. Push my old Haas to 2500 rpm tap speed and go. If it would handle rigid faster I would but I think its only rated for 2k. One tap is on aprox hole #9k
    Jun 2012
    Michigan
    5,208
    4788
    3150
    Quote Originally Posted by swarf_rat View Post
    What machine?
    I would tap as fast as your machine can tap accurately. Rigid tap.
    Of course on our Brother I would go 6k rpm, but on our Hyundai-Kia Fanuc 0 mill, I wouldn't even try it because the spindle can't stop and reverse fast enough, so about 300rpm max.
    Our Okuma mills I would go about 3k rpm or so.
    Feb 2004
    Napa, CA
    2,632
    45
    698
    I am unfortunately familiar with foreign aluminum and always buy US sourced product. The machine is a DMC63V, not sure what speed it might be rated for. The positioning is accurate (glass scales) but how quickly it can start or stop I don't know.
    Feb 2013
    Idaho
    765
    172
    881
    I don't get to carried away with tap RPM... 500 for prototype and 1000 for production. Prevents math errors and I think it is easier on the machine. On 800 holes I wouldn't get to excited about the potential improvement in cycle time to go up into the multiple of thousands.
    I have had difficulty with small threaded holes in aluminum. The threads looked fine and I didn't break many taps, but I have had issues getting them to pass QC. Whenever I get much below 2-56, I have a tendency to ream the holes after drilling. I consider the error in hole diameter and the subsequent impact to the other thread dimensions to be a percentage, rather than a straight numerical error. In other words, a couple thou error in diameter on a 1/4-20 is much less significant that the same diametrical (big word bonus points) error in a 0-80... unfortunately, my potential error in drill diameter seems to be about the same regardless of drill size.
    I think that some of the modern stub length carbide "engineered" drills can hold drastically better tolerance than the old HSS jobber drills, but it seems to take more fiddle fucking with drill sizes and cutting conditions than ordering reamers in a couple tenth increments and picking the one that gages out correctly. Especially considering the relatively low volume of holes you need to tap.
  9. Likes Chris59, hanermo liked this post
  10. #8
    Apr 2007
    West Virginia
    1,132
    666
    484
    I never have done M2 but lots of M3 holes. I will second what G00 Proto said- start by making sure your hole diameters are what you think they should be before you start tapping. I gone wrong here before.
  11. #9
    Feb 2004
    Napa, CA
    2,632
    45
    698
    I think I'll try a rigid holder and start at 500 rpm to see how it goes. The hole diameter thing is why I'm reluctant to use form taps for this or other short runs. There are numerous studies indicating that formed thread are great - provided you have exactly the right pilot hole diameter. Otherwise, they can be crap and still pass QC because of the formed shape. In long runs you can spend the time to get them just right. Cut threads on the other hand can have fairly large variations on pilot hole without big changes in strength.
  12. #10
    Sep 2017
    Wisconsin
    982
    228
    628
    On a Speedio I would run that rigid with a form tap at 6k RPM.
  13. #11
    Feb 2004
    Napa, CA
    2,632
    45
    698
    Wonder if it actually gets to 6K? 10mm at 0.4 is only 25 revolutions. 1/4 of a second at 6K. It can come up to speed out of the hole, but must stop and reverse in the hole. What is the acceleration rate of that Speedio spindle?
  14. #12
    Sep 2007
    Washington
    5,430
    225
    1701
    Oh geez, don’t get us Speedio guys going, we’ll never shut up
    The spindle accel/ decel is PDQ. I would not be surprised if my S700 could hit 6,000 in this scenario, but I don’t really know.
    Regards.
    Mike
  15. Likes Mtndew, Pete Deal liked this post
  16. #13
    Dec 2013
    848
    255
    495
    Speedio spindle takes less than .1 seconds to get to 6k. At 6k it's almost like a light switch. You can go from M3 to M4 at 6k and you might not see it reverse. Here is a video of Synchronized tapping on Brother:
    YouTube
  17. #14
    Aug 2013
    Chicago, IL
    1,032
    730
    402
    I am curious - is there some accuracy “standard” a tapping process must conform to in order for it to be considered “rigid tapping”? I am knee-deep in a rigid vs non-rigid tapping situation at work so it’s on my mind. I am thinking something like, “spindle rotation must be within “x” degrees of theoretical position for a given linear position as a function of thread pitch.” or something. On that note, how “off” is a machine without rigid tapping? Like - what’s the difference in terms of real numbers?
  18. #15
    Sep 2002
    People's Republic
    4,461
    434
    2711
    Form tap!
    the difference in speed on that machine between 1k and 2k rpm is small. 500 is just silly slow
    drill with a standard hole drill, measure actual hole size, tap, check with gauge and also check minor diameter
    thread can pass the gage but fail the minor. Even if you have get an odd size drill, it is worth it. The smaller and finer the fussier they are going to get.
    you should break zero taps and have that tap for years
    I think we get over 20k holes out of #6, maybe 50k I dunno
  19. #16
    Oct 2007
    SPAIN
    3,938
    2296
    1550
    It depends how big/good your machine is. Robodrills will acc/dec faster than #40 taper machines.
    I would rolltap with bright finish tap (no coating) at S1500 and 10% concentration coolant
  20. #17
    Sep 2009
    barcelona, spain
    2,458
    552
    1462
    I am very interested in the final result.
    Please post.
    Have no doubt the brother spindle, as a servo motor, can get to 6000 rpm in 0.1 secs, as posted previously.
    At 6000 rpm, 0.4 mm / rev, or 100 revs/sec, it would be ..
    .. 25 revs (10 mm deep) in 0.25 secs.
    If the brother spindle can reverse in 0.1 secs, this would be 10 revs or 4 mm in depth at 0.4 mm/rev from 6000 rpm.
    Very curious to know actual specs and actual results.
  21. #18
    Mar 2015
    Connecticut
    16
    34
    11
    Tapmatic, no spindle reversing.
  22. #19
    Feb 2004
    Napa, CA
    2,632
    45
    698
    Quote Originally Posted by WRL View Post
    But, a host of other problems.
  23. #20
    Mar 2015
    Connecticut
    16
    34
    11
    I’ve had good luck with them.
