KristianSilva
- Nov 26, 2016
Hi,
I have a problem with snapping M4 taps, I think what is happening is that after the first hole or two swarf is building up on the tap and causing the tap to jam up with swarf. How can I clear this swarf?
Material is mild steel and the tap is a spiral flute tap for steel and im using the correct cutting data.
