soft jaw rack?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: soft jaw rack?
    Apr 2014
    AUSTRALIA
    633
    245
    157
    Default soft jaw rack?
    Hey guys,
    My soft jaws are annoying me constantly getting in the way and whatnot.
    Just wondering if anyone had an ingenious method of storing them? I was thinking some sort of peg board might be the go so they are all nicely visible, but also have their own spot to live.
    Pictures are always helpful.
    Cheers,
    Trav
    I just tidied up my collection. 35 soft jaw sets and 1 hard jaw set...
    Oct 2014
    AUSTRALIA
    272
    61
    83
    Dont you spray your jaws when youre finished? lol. I use a big BAC SYSTEMS trolley with drawers for all my soft jaws. And yes its BIG cause i have shitloads of them. I also use autobloc force compensating chucks and between the two mazaks both using the same chuck we can swap the jaws between the machines without the need for skimming them for accuracy UNLESS its very critical. For 90% of the work we dont bother.
    Open Center Power Chucks, BHD-FC, Centrifugal Force Compensation
    thats the chuck that i use. I run jobs with light to moderate clamping with these things and never once had a problem. I wouldnt dream of doing some of the work on a kitagawa chuck using the same chucking pressure.
    May 2008
    SOUTH AFRICA
    1,660
    1227
    683
    Do you need it to be really neat and practical or just practical?
    My uncle's shop has a really long shelf with all of them laid out nicely next to each other (Practical and neat but takes up waaaay too much space for my liking)
    I,and I don't have pics right now, have 3 different setups for jaws. For my small kia lathe I just use the small cupboard on the front of the machine to store them because my hard jaws and 6 sets of soft fit in there nicely. On my big takisawa I made a board with hooks from an old shelf,sprayed it up and welded hooks on, for the smaller jaws and spacer rings but I also had to make a small shelf that doubles as a tiny work bench for the big jaws (some of the special jaws that I have are really big so the hook system would not work). At the old lathe inside the main shop I made a bigger self standing shelf with round bars welded on where the jaws can slide over because the little thing has a crap load of different jaws. Each bar there can hold up to 2 full sets of jaws.
    Aug 2016
    UNITED KINGDOM
    116
    23
    37
    We're considering storing ours in the skip because despite having hundreds of the damn things we can never find the ones we want anyway.
    Mar 2004
    Waukesha, WI
    7,382
    715
    1835
    Quote Originally Posted by barratt View Post
    Storing them in the skip? What does that mean?
    Apr 2014
    AUSTRALIA
    633
    245
    157
    Quote Originally Posted by Dave K View Post
    Throwing them in the garbage
    Sent from my HTC One using Tapatalk
    Mar 2004
    Waukesha, WI
    7,382
    715
    1835
    Quote Originally Posted by xa-mont View Post
    Ha! Ok, that's a new one on me.
  8. Likes xa-mont liked this post
  9. #8
    Oct 2013
    New Jersey
    1,335
    7
    1153
    I think this looks like a pegboard kind of job, but very heavy duty. How about laminating two sheets of 3/4" plywood together so you can drill holes at a slight angle upwards for rods you would hang each set on? I'd label the columns and rows with numbers x letters, then build a spreadsheet listing them by size, type etc. and the pin they are on. Location can be rather random and you can find them instantly.
  10. #9
    Mar 2010
    N.E. PA
    802
    85
    251
    Here i what I use. Welded frame with a plywood bottom.img_0826.jpgimg_0824.jpgimg_0827.jpg
    John
  11. #10
    Apr 2013
    South Australia
    468
    126
    148
    Bit of angle, drill some holes far enough apart for jaws to sit side by side with a bit of clearance. Cut some 10mm pins about 100 long. weld pins into holes and then mount the angle to the back of a bench and you're done. looks like a rake when finished
  12. #11
    Jul 2016
    CANADA
    Ontario
    48
    13
    15
    How about something like a bolt bin?
  13. Likes Philabuster liked this post
  14. #12
    Apr 2014
    AUSTRALIA
    633
    245
    157
    here's what i came up with. it's just sitting there for now, but will be painted and then mounted to the machine.
  15. #13
    Aug 2016
    Arkansas
    Alot to think about :s Just wanted to say I've had my service done With Servicing Stop and they are really good! They picked my car up from mine on time, took my car to a local garage, called me up to confirm anything that needed doing and dropped my car back off to mine, all within the time they said! Quick and easy, would recommend to anyone who has a busy life or just in general!
  16. #14
    Apr 2013
    South Australia
    468
    126
    148
    Quote Originally Posted by jacklem1 View Post
    WTF are you on about
  17. Likes sophtayl liked this post
  18. #15
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17467
    Quote Originally Posted by sudsy55 View Post
    He's spamming - that same load of squit was tacked on to a thread in General.
  19. #16
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17467
    Piss off Noddy!
  20. #17
    Nov 2012
    Wisconsin
    2,338
    3864
    2890
    Quote Originally Posted by Limy Sami View Post
    Piss off Noddy!
    No idea what a Noddy is (one of the things I like about PM) but if I say "piss off Noddy" in my 'ead wit an English accent......it makes me not want to be one. lol
    Pretty sure that around here we would call him a jerk-off.
  21. #18
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17467
    Quote Originally Posted by toolsteel View Post
    FYI - Noddy Noddy (character) - Wikipedia, the free encyclopedia
  22. Likes toolsteel, Philabuster liked this post
  23. #19
    Jul 2006
    Wisconsin
    1,458
    293
    1041
    I have mine in a Vidmar cabinet. Some jaws stand up nice and can see the back end which is marked with size or job info,a few are too tall to stand up. Pull out drawer find the set I want and put them on. Just make sure cabinet is bolted down or at least has several heavy drawers so it doesn't tip when pulling out one.
    I dont have tons of them yet. The ones that get used alot have the size info engraved instead of paint pen. The drawers will hold alot as I have one with three Kurt double lock vise beds in when they arent being used. (HDLM6 vises with jaw carriers in different drawer)
  24. Likes Philabuster, yardbird liked this post
  25. #20
    Mar 2014
    BLACK MOUNTAIN NORTH CAROLINA USA
    366
    356
    236
    Nice job JP Machining , I have about 10 drawers like the photo above , I use a sharpie to write the size on the jaws , sometimes even part #s , before using I take a cell phone photo , when job is complete , I remark jaws with sharpie. Works for me.
  26. Likes Mud liked this post
