Soft Limit Alarm Fanuc 10m
Results 1 to 3 of 3
    Oct 2019
    Minnesota
    11
    Default Soft Limit Alarm Fanuc 10m
    I just wasn't sure where to post this info so hopefully you'll find it if you're looking for it.
    With all the issues I've seen about soft limit alarms and how to clear them this is what I learned from an old tech friend of mine. And it worked for me.
    On my old Kitamura MyCenter 1B with a 10m Fanuc Control, I have used this procedure to clear the register.
    Machine over-travel will give you this alarm:
    0T001 OT Soft Limit
    So shut 'OFF' the Main Power on the machine
    Then turn the Main Power back 'ON'
    Then Press & Hold the 'decimal point' AND the 'minus' at the same time holding them while you turn 'ON' the CONTROL POWER. Then release the 'decimal and minus' buttons
    You will get a list on the screen of 1-6
    Choose 4 and press 'Input'
    Then press 'N' (just 'N' DO NOT press Input, not not not)
    Then press '6' 'Input'
    This should clear out the register and you can 'Home' the machine
    Hope this helps
    Sep 2010
    india
    1,370
    75
    261
    This has been simplified on newer machines. We just have to move the tool in the other direction (permitted zone). Press RESET.
  3. Likes EnginCycles liked this post
    Oct 2009
    Oregon
    5,992
    6478
    3345
    I think it depends on the builder.
    My late 10M-D Mori just stops you from moving any further and lets you move back and hit reset.
    If one of the hard overtravel switches is stuck it will be in E-stop until I disconnect the switch and jog it back though, but that only happened when I moved it.
