Solid Carbide Taps
Results 1 to 20 of 20
    Jun 2009
    Clearwater, FL
    121
    14
    Default Solid Carbide Taps
    I was gathering a list of tooling I'll need for a job I'm working on, and came across solid carbide taps. I've seen them before, but never paid them much attention. What struck me as odd, is that they specify them for use only in aluminum and cast iron, the opposite being true with most other cutting tools. Is that because carbide taps are too brittle for harder materials? When are these worth it? Are they just able to be run much faster? I called OSG with my questions, and all I managed to get was the phone girl, who was pretty much just reading a catalogue.
    I'd be interested to hear thoughts on them from anyone with experience.
    Jun 2013
    Oregon
    2,010
    737
    1223
    Probably for abrasive materials.
  3. Likes mhajicek liked this post
    Sep 2014
    Georgia
    1,040
    10
    267
    Probably useful in very abrasive aluminum alloys.
    I have briefly seen them but never much thought due to price and I don’t run production.
    It would make a lot of sense for roll taps. Where the brittle nature of carbide probably won’t cause as much of a problem
    Jun 2012
    Michigan
    6,145
    5754
    3928
    Quote Originally Posted by JBethell View Post
    Pretty much.
    The chance of chipping the cutting edge is much greater even in stuff like 1018 with a carbide tap.
    Maybe if you have peck tapping you can cut harder materials but I've never tried it. I'll just thread mill if I need threads in harder stuff.
    Jun 2009
    Clearwater, FL
    121
    14
    Cool, I just found it odd to see carbide specifically recommended for only aluminum. Probably not enough benefit to outweigh the cost unless you're running super high production.
    Jul 2006
    Hillsboro, New Hampshire
    14,118
    3083
    9358
    The main issue with carbide taps is their dislike of being rotated counter to the clearance geometry. So while lathe inserts and milling cutters will always (bar screwups) run with the cutting edges working as designed, taps HAVE to run backwards to clear the hole again. The drag of the cutting edge rubbing against the tapped hole threads damages the cutting edges, basically fracturing them at a micro-level.
    This is why you can use carbide taps in softer abrasive materials like hi-silicon Al or fiberglass reinforced composites, but not in hard steels. As mentioned, you're much better off using threadmills in those situations.
  8. Likes adh2000, couch liked this post
  9. #7
    Nov 2014
    Florida
    6,367
    2537
    3151
    We use regukar hss or cobalt form taps for aluminum and brass. Either uncoated or TiCN....
  10. #8
    Jun 2009
    Clearwater, FL
    121
    14
    Yea, same for me. I just saw the carbide taps, and thought I'd educate myself on something new. I ask a lot of questions, 😂😂
  11. Likes Mike1974 liked this post
  12. #9
    Aug 2010
    Medina OH
    2,380
    344
    1183
    One of the shops I worked at used Carbide taps up to M20 for die details up to 62Rc. Not sure why they would tell you that they are aluminum specific? Maybe the taps we were using were something different?
    I never understood the time and money aspect, those carbide taps were insanely expensive. They broke, often. It would have been better to use a sinker EDM, but what the hell, I wasn't paying for them and management said sinkers were ancient technology no one uses anymore.
  13. Likes Ox liked this post
  14. #10
    Jun 2009
    Kentucky
    237
    47
    77
    seen them used in glass filled plastics really abrasive stuff.
    material would really wear down a cutting edge on carbide. if you looked at it with magnification it looked the edge was polished off.
    this was before diamond coatings came out
  15. #11
    Jul 2006
    14,118
    3083
    9358
    Quote Originally Posted by Fal Grunt View Post
    Sounds crazy when there's carbide threadmills available. Damn...
  16. #12
    Jun 2012
    Michigan
    6,145
    5754
    3928
    Is that place still in business? lol
  17. Likes TeachMePlease, mhajicek, mountie liked this post
  18. #13
    May 2007
    Yadkinville, NC
    204
    We keep a few sizes of solid carbide taps here for use on some parts we make from G10. HSS taps were lasting for a handful of holes, we get a few dozen with the carbide ones.
  19. Likes mhajicek liked this post
  20. #14
    Aug 2010
    Medina OH
    2,380
    344
    1183
    I don't know, they had some really odd ways of doing things.
    Quote Originally Posted by Mtndew View Post
    Their revenue was around $18 Billion last year....
  21. Likes Mtndew, Eric U liked this post
  22. #15
    Aug 2006
    Wisconsin
    1,778
    810
    836
    We don't use carbide taps much, I did however do a demo on an OSG tap because I thought the guys were full of shit. I tapped over 60 holes in S-7, 54-56 R.C. before the tap broke. It does work, and you MUST rigid tap, It just seems rather pointless to me.
  23. #16
    Jan 2014
    Temecula, Ca
    3,449
    1425
    4469
    we used carbide taps to clean out the threads in D2 after heat treat. We'd chase them with an H7 before HT, but sometimes they'd need to be cleaned out after HT.
    Otherwise, they just chip too easy.
  24. #17
    Dec 2007
    Idaho Falls
    68
    27
    14
    We use Carbide Form taps to tap 8-32 holes in 303SS all day long safely 45,000 holes per tap with a 2.5 pitch chamfer and straight oil.
  25. #18
    Jun 2009
    Clearwater, FL
    121
    14
    Quote Originally Posted by csteen View Post
    45,000 holes??? Thats impressive!
  26. #19
    Sep 2014
    Georgia
    1,040
    10
    267
    Yep that’s exactly where I figured carbide taps would really shine. Roll taps.
  27. #20
    Dec 2007
    Idaho Falls
    68
    27
    14
    Yes, 45,000 safely the hole is only .25 deep though. In testing I got up to 62,400 holes. I would really like to get a synchro type flex holder and see if that helps it more. We do 300,000 to 400,000 of that particular part annually.
