A somewhat basic turning question
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2017
    IRELAND
    10
    Default A somewhat basic turning question
    I have a job on titanium (eli) .turning 8mm stock to 1.7mm.
    6000rpm.
    0.01mm rev.
    Works a treat. No chip build up. Prefect finish.
    D type insert with a 0.2 mm radius.
    Now I started a similar job today.same stock. But to 2.7mm
    Getting some chip wrap.
    Still running at 6000rpm.
    If I drop to 4000 rpm to match surface speed so should I expect my chip issue to go away?
    My cutting time will increase. How do I maintain cutting time.
    Would have liked to have tried more today but ran out of time
    Jun 2011
    New Jersey
    1,785
    986
    811
    Quote Originally Posted by seanied View Post
    6000rpm.
    0.01mm rev.
    Sounds like perhaps just slowing a little may help, but you might want to make sure your chip load and feed rate are correct.
    Oct 2007
    SPAIN
    5,732
    1575
    860
    So if it is the same batch of mtl, the same speeds and feeds, the same set up, the same part and program BUT the finished diameter is bigger....silly question....
    Did you swap for a new insert?
