DMSentra
Cast Iron
- Sep 12, 2008
- Eugene Oregon
This mill has a tank on each side of the machine and a 1 7/8" - 2" hose between them. Anyone have a source for hose or know if there's a particular grade of hose needed?
I had a big 70 mill with a swimming pool on each side, I used the nylon reinforced hose from home depot, kinda clear blue strings if I recall. I know I got it from home depot and it was either 2 or 2.25"
Never had a leak and worked for about 6 years till I sold the machine.
We use hose I found in the irrigation section at the local farm store. It's green and clear spiral plastic, no idea what material it's made of. We use the irrigation quick disconnects also, makes it easy to unhook when the tanks need cleaned out.
I am also in need of 1" ID hose to connect the 50 gal tank under a pallet changer to the 250 gal tank on the other side of the machine. And have been contemplating what to use, though I haven't put much thought or effort into it yet.
I used that clear stuff you are talking about years ago on a manual mill and after a year our two (maybe less, can't remember) it became extremely hard. It has never broken or leaked but it turned into hard plastic which would be less than ideal for my tank under the pallet changer which should roll out to easily pull the chip screen.
Your best bet is have flanges welded on to the tanks. Get stainless pipe with flanges welded to fit and bolt them up. Then it will be done right.
Last shop I worked at used plain old compressed air hose (goodyear I believe) for a coolant washdown hose. I laughed at boss when he installed it, but 8-9 years later it was still perfect. I used same thing when on my machine when I setup my shop and thats working fine too. I guess traces of oil are not uncommon in air lines so I guess they are made with some oil resistance.
I'm sure Aeroquip has a -32 PTFE lined hose that would work great....if anyone besides NASA could afford it.
Going over to AN stuff? It won't leak.... it'd be damn expensive....but it won't leak.That's actually a good idea, not for the coolant line but for all the leaky air lines.....
Notice
