source for Fadal lube line ,door bearings and way cover plastic part
Likes Likes:  0
Results 1 to 3 of 3
    Dec 2005
    Iowa
    208
    19
    Default source for Fadal lube line ,door bearings and way cover plastic part
    Hi Thanks again for all the help from you guys. I need a new X axis lube line that is the the nylon line with a ferrule on each end. for some reasom it was stickig out of the side of the cst track cut in two. Cat track is fine Also I need the needle bearings for the bottom of the front doors. And can I get the plastic slider parts that are a .060" plastic strip bent in a 180 degree with a rivet in each end that the middle part of the X axis way cover slides on I have bought several parts from Fadal CNC but I don.t see these items listed. They do list the complete door bracket with bearing but I just need the needle bearings. they are .250 ID .4375 OD x .250 wide.
    Jan 2019
    Arizona
    531
    36
    186
    Mc Master carr
    Sep 2008
    1,528
    970
    882
    Quote Originally Posted by garychipmaker View Post
    ITS in Chatsworth or FadalCNC
