Having trouble eliminating chatter marks in a deep pocket.
Material is 6061. Final depth is 2.75 inches.
Using a 1/2" 6-flute HSS end mill with 3 inch flute length.
Pocket geometry is 0.6 x 1.075.
Machine is a Kitamura MyCenter0. BT30 spindle.
I first hog the material out by drilling and then rough it with the end mill leaving 0.010 for a finish pass.
I've tried multiple combinations of speed/feed and still end up with chatter marks.
I also have a 11.5mm carbide 4-flute end mill that I could use if that would be better. Also wondered if conventional cutting on the finish pass would help?
Any help would be much appreciated.
gm
gm
