trochoidalpath
Cast Iron
- Jan 17, 2016
I ran into something really weird on my Speedio trying to copy files around. Before I really lose myself in the manuals trying to figure it out....
I have a program on a USB stick, named O1234.NC. Insert USB stick, file is visible and all that. Press EDIT, External Program I/O, key in 1234, Input. No luck, throws a “transfer error.”
If I instead switch to the right side window, scroll down, select the program, then Input, the program copies over fine and I can run it like normal.
If I try and delete the program from the control, keying in 1234 then Delete throws an error “7544 required data not found.”
I must have screwed something up — any ideas?
