Houndogforever
Hot Rolled
- Oct 20, 2015
- Boring
Yeah, I just said that.
I have a part, measures about 4x7. It gets milled into a layed down H shape. I currently do it in my trusty Fadal 3016, but I was wondering.
It needs to be milled .92 deep and each leg and cross beam of the H measures 20mm (.787)wide.
I have done it a few times on my Fadal, using a 1/2" Emco 5 flute, full axial depth and a .075 radial. I believe that runs about 470 SFM at .0054 ipt.
I don't reckon the little speedio BT30 isn't going to take a .075 radial cut.
The inside corners wont jam up the endmill as they are OS at this stage. I come back in with 1/4 and 3/8 tools later.
So, P20 steel, S700X1 Speedio 16K and a lot of material to be peeled off.
What would you guys run this at?
