Wsurfer
Cast Iron
- Apr 1, 2013
- Austin Texas
Hi all. Had the speedio since January. My common setup is 2 kurt d688's that don't get moved for moths. The first time I pulled them off, there is significant rust growth, but only on the table and not so much on the vise. The rest of the machine is spotless using trim microsol 685. I used some grease between the two, but doesn't seem to help, or maybe that's the problem. Is this galvanic corrosion ?. If so, would a conductive type grease be better ?.
Matt
Matt
