Spherical Radius
Results 1 to 7 of 7
    Aug 2019
    Oklahoma
    Default Spherical Radius
    im trying to program a spherical radius. my OD .211 im using a .015r insert.
    the start of my program is
    x.500 z0.0
    G1x-.04
    -.03
    G2x.211z.1205R.1205
    the issue im having is im getting a .035 flat on my face. im noy using any TNC any suggestions?
    Sep 2015
    Ohio
    1,031
    595
    1003
    You need to add your tool radius to the finish Z and radius you are cutting.
    Basically you have to program to the tangent points of the tool radius.
    X-.03
    G2 X.211 Z-.1205 R.1205
    Nov 2013
    Utah
    4,255
    1152
    2323
    Quote Originally Posted by Booze Daily View Post
    X-.03
    I'm not going to point out the G2 for the OD---oops.
    But isn't what you posted exactly what he posted?
    My guess is he's using a .0312"r insert. If not, he can try feeding into Z by .0098 then finish at Z-.1293. That will be the Tangency of the insert radius.
    R
    Mar 2017
    Minnesota
    6
    8
    R
    He is turning from Z0 to Z.1205 (positive) so G2 is correct.
    Nov 2013
    Utah
    4,255
    1152
    2323
    Quote Originally Posted by ThunderPants View Post
    Nope, sorry. G2 is a clockwise arc.
    R
    EDIT> I can see clearly now the rain is gone. Unless he's using a sub, or the programming is all wonky, it's redundant anyway. Besides first time poster, probably won't respond anyway.
    Mar 2017
    Minnesota
    6
    8
    R
    Depends on the machine type, right? My Citizen M and L machines are always Z+ for forward turning (main or sub, using tooling on the turret, gang slide, or back post) and G2 would swing the correct direction for turning a spherical OD feature. I was assuming he knew his machine. But, maybe he doesn't and that's his problem. I suppose no one is right or wrong without more information.
  7. Likes TeachMePlease liked this post
    May 2008
    SOUTH AFRICA
    1,589
    1169
    658
    Tell me about it... The Mori SL2 that I am trying to get used to use Negative X values. So 50mm is X-50.0
