xa-mont
Hot Rolled
- Apr 4, 2014
- Victoria, Australia
Hey guys,
I recently (well actually quite a while ago, but only just got it running) bought a Hartford hv35 vmc.
I got the manuals for the machine after running new air lines (they were all cracked) as i noticed 3 hydraulic lines not connected to anything - 2 of them are for the spindle chiller. I called the PO of the machine and he never had a chiller on it that he can recall (only hobby use by him basically).
So my question is... is it necesarry? it's got an 8krpm spindle (belt drive from motor to spindle assembly, not sure what the reduction is, haven't checked) and i plan on using it at or near that 8krpm fairly regularly (this will mostly be running aluminium as my mazak vqc20/40 is just too slow)
I'm currently running some continuous running tests on it to see how the temps go and so far after 45 mins of running (first 15 at 4krpm, then 6krpm - then 8krpm) the hottest part on the spindle housing is only ~10.5*c over ambient, while my vqc (that has been running for about 8 hours straight at this point, mostly at its 4krpm max) shows a hottest point at ~14*c over ambient (all the covers are on so I could possibly get a higher reading at a different spot with the covers off)
I was thinking of maybe just putting a basic pump/res setup on it to circulate some oil through it in case it's the lubrication oil as well in the spindle, which will also in turn work as a rudimentary cooler (just be the higher volume of oil - unless the pump produces more heat therefore negating the advantage... not sure on that)
Cheers,
Trav
Cheers,
Trav
